Heh, . There’s definitely a lot of tweaking going on. If only there was more “completing of projects” or “producing of buck drivers” going on.
Remember that the ATtiny25 is physically the same as the ATtiny13A. Porting to the ATtiny25 should pay off for all drivers which currently use the ATtiny13A! That’s why the 25 was selected instead of the 45 or 85, which are both slightly larger and don’t fit properly on these tight PCBs.
And pray tell what does “Porting” mean? Last time I ported anything I bored holes in the end of a .45 Long Colt barrel so the handloads I was feeding it didn’t make the front sight attack me.
essentially yes, but “porting” usually implies taking the existing program and just tweaking little parts of it to make it work on different hardware. the overall program will be mostly the same, just little “nuts and bolts” will change. However, with the extra space available on the 25, I would expect the programs to get much more feature-rich (and therefore complicated) once it is ported.
I think a lot of the space issues crop up with features such as:
Momentary button support. (e-switch)
Thermal throttling.
Any use of curves with tables? (fancy ramping)
Complex UI.
I’m probably forgetting some things, and since I have not been attacking these things myself I don’t know how big a problem features like status LEDs have presented in terms of space.
A production run would be cool, but first we’d need to settle on a “final” design for it. Wight has been improving things almost daily, so it’s not really stable yet.
However, I get the impression that the most popular driver would probably be a 17mm single-sided model with both a FET and a single 7135 chip, OTC, and attiny13a or attiny25. If there’s room, also a pad for a zener. This would cover almost everyone’s needs in the most common size of light — blinding highs, low and efficient lows, off-time or e-switch UI, several popular firmwares, and easy to reflash. Not much room for solder stars though, so people would need to mostly agree on a default firmware.
He also made a pretty amazing 15mm model with everything above except a zener, which I’m hoping to try soon in some 1x14500 lights.
I make a good living off of porting code - that's what I seem to do most of the time, lately, for the last few years... We went from custom embedded hardware (1st generation) in ASM/C/C++, to COTS (Commercial Off The Shelf) boards w/custom plug-in hardware (2nd generation) Win CE based in C++, and now (3rd generation) to Windows based Panel and table PC's in C#/.NET . Maybe 150k-200k LOC's (Lines of Code) ported along the way...
I’m glad I haven’t had to port code very much. Occasionally fix bit depth or endian issues, yes. But mostly I get to use Python and shell, which makes all that moot. Before attiny firmware, I think the last time I had used C was in the 90s. But I like C, it’s still one of my favorite languages. I’d probably like Go too, but I haven’t really used it yet.
Most of the code I write is basically prototyping anyway. Proofs of concept to decide on a good design or test potential solutions, and then if it turns into important infrastructure someone else can maintain it. Or little bits of code to break things. Or anything which satisfies the rule of three — the third time I have to do something nontrivial, I automate it.
I built a BLF17DD from Mountain Electronics. It didn’t work. Positive and negative in were shorted together. I saw a line across the positive LED pad and scratched it out with my camel bone handled pocket knife, which fixed it.
