How hard, or risky, is it to attach a spring or little brass contact bump to these boards?
What’s the best way?
Low temp solder bond- no risk at all
I have one of the drivers re-springed like 7 times( i have realtively steady hand), its very well made indeed( the driver), and it seems a higher temp solder paste was used when it was made
Here, A type spring plus 22 awg soft silicone wire is the best, believe me, i tried everything, its better even over brass or CU pills
Why should it be better than a cu pill?
Tested it with a Cu pill cut from a 6mm Cu rod bought from Practiker store nearby - cut it, then machine sand it , yet the spring is better, maybe the CU wasnt pure enough…definately not oxygen free like a quality wire…(if you find a silver plated wire- the better)…maybe a high quality rod will do, wonder where to find those
Any updates? Id love to buy some from you.
Patient you must be.
Is there a picture showing exactly where to solder on the red and black wires?
EDIT nevermind, I found it: http://i58.tinypic.com/2hyz77l.jpg
in the other thread: LD-1 driver (5A pwm-less linear) info thread
want :bigsmile:
Padawan impatient, resist the dark side he must.
Any updates? Please… oh, please… :bigsmile: can I buy some soon?
I’m also waiting………and waiting………………… 0:)
I have one left that I will sell. I will include shipping and will only ship to USA as int’l is too much hassle. Will take bids by PM.
ill pay u what u paid for it :)
I’ll pay ten cents more! :bigsmile:
I have the vague recollection that some popular mod lights have been mentioned as being suitable — or not — for use of this driver.
Maybe one warning that it could overheat the driver.
Anyone recall any specifics about lights to use, or to avoid, for this one?
(C’mon, convince me I need several more lights … or not …)
PM sent
Subscribed for availability updates.
So, how about second batch?
Also subscribing
