This is an ultrafire c 308 battery tube that fits but just looks stupid.I am pretty pumped to get this now and finally finish what I started.This light in shorty mode is awesome, now to search out 5+ amp driver.Thanks for confirming the fit Warhawk!
Thanks guys for all the answers regarding the tail cap fit. It seems there are a few people with loose tail cap threads but for $9 you complain too much! By the way mine has been lubed with silicon grease and it is BY FAR the loosest fitting tail cap out of over 100 lights I own. Anyway I have ordered another and hopefully this one is better.
> won’t quite lock out by unscrewing the tail cap after some wear,
> because some aluminum shows through the anodizing
Cautionary. Do you think a wrap with teflon tape would work, or would it eat up the tape?
I guess the threads aren’t particularly smooth since they ate up the anodizing.
It is more that the anodizing is thin. On the Yezl, it is more the rough threads. Teflon tape might be too thin to use on my twisty Yezl, but I think it would work on this one.
Just ordered two of them for my DST’s. Used the store points and it comes out to about $6.50/piece. Love 26650’s. It might look strange, but I like it.
Ordered two and got my first one today. The threads are very very loose in the end so there will be a fix somehow. The tube sayes XM-L2 on mine and it is one inside. Very nice beam.
No complaining, it´s a cheap light and we like to fix things in here so…
I put both, an MT-G2 and SST-90 in one of these, I didn’t like the beam of either emitter with this reflector, they both had artifacts that I couldn’t get rid of and the stainless steel bezel creates a ring in the outer portion of the beam that I didn’t like.
IIRC with an XM-L2 the hotspot was quite large when I swapped the stock centering ring for a ‘normal’ thin/winged one. Before that I think maybe it was not very good? Ringy or something? I don’t recall. I do wonder a little what the XHP50 would do.
I ordered one on 1/17 and received it today. What!? I checked my account and it turns out I had ordered one on 1/3. So it took 17 days to get here and not 3.
The tail cap is fine on my sample. I did have to grease all the threads. The light is pretty much as Old Lumens reviewed.
Now I just need to assemble a BLF17DD driver and flash a custom firmware and I’ll have a true budget light.
