It is more that the anodizing is thin. On the Yezl, it is more the rough threads. Teflon tape might be too thin to use on my twisty Yezl, but I think it would work on this one.
Just ordered two of them for my DST’s. Used the store points and it comes out to about $6.50/piece. Love 26650’s. It might look strange, but I like it.
Ordered two and got my first one today. The threads are very very loose in the end so there will be a fix somehow. The tube sayes XM-L2 on mine and it is one inside. Very nice beam.
No complaining, it´s a cheap light and we like to fix things in here so…
I put both, an MT-G2 and SST-90 in one of these, I didn’t like the beam of either emitter with this reflector, they both had artifacts that I couldn’t get rid of and the stainless steel bezel creates a ring in the outer portion of the beam that I didn’t like.
IIRC with an XM-L2 the hotspot was quite large when I swapped the stock centering ring for a ‘normal’ thin/winged one. Before that I think maybe it was not very good? Ringy or something? I don’t recall. I do wonder a little what the XHP50 would do.
I ordered one on 1/17 and received it today. What!? I checked my account and it turns out I had ordered one on 1/3. So it took 17 days to get here and not 3.
The tail cap is fine on my sample. I did have to grease all the threads. The light is pretty much as Old Lumens reviewed.
Now I just need to assemble a BLF17DD driver and flash a custom firmware and I’ll have a true budget light.
Thanks WarHawk-AVG. I wasn’t trying to steer dthoang away from the BLF22DD, I just noticed the specific mention of the BLF17DD. I figured I’d mention the size consideration to try and prevent tears.
I’ve been thinking that I should do some new 22mm boards. There have been plenty of interesting developments since the last 22mm boards were done.
EDIT: Your post is maybe a little confusing to those who don’t know. Why don’t you put the hyperlink to the BLF22DD on the BLF22DD text instead of the BLF17DD text? :~
Yes, it took some days but it seems that I will get a refund. I’ve ordered another one in between and was assured that the current model will be shipped. Let’s see what I will get this time…
Today I’ve got 3 XM-L’s from FastTech which I was planning to use for replacements (mounted on 20mm stars because I’m not in the reflowing business yet). Although only two of them should be XM-L2 according to my order, I’ve got all 3 as XM-L2 with silverish top (all T6 bin with 1A/1C/3B tint). Let’s see what I can do with them.
I received mine today also, and it too has XML-T6 stamped on the side and thats what is inside (no thermal paste at all just loose on top of shelf) Driver is slightly different than what has been posted, a YN-22-T6 different position of some components.
Gearbest customer service are quick in replying , I emailed them yesterday and today they replied offering replacement or refund , I asked for replacement as long as it has XML2, the XML I have is not that bright and has a lot of blue tint in it.
This batch is worse quality than the first batch. Very poor, even at the price point.
Sorry, I just can't know for sure what we will get any more and it seems to get worse every time. Even if I ask for a sample first, I don't know if that sample will be representative of the actual lights going out.
