I actually tried baton on my test rig, and it was close to what I wanted, but i thought it would be easier to use plain STAR as my stepping point.
The main things I didn’t like:
- I don’t like to use a double click as a commonly used function (just preference)
I wanted the cycle to always start at moon, not the last mode.
I do like how you’ve implemented the lockout, but I’d rather have the unlock function to be a double click (just because that’s less likely to happen in a pocket than a long press is)
Is it possible to have a long press from off to lockout, and a double click to unlock to moon?
The reason it works that way is simply because I was copying an existing interface. It doesn’t have to stay that way.
I think a double click could be used to unlock; I just haven’t ever tried it.
The memory could also be removed, which would simplify the interface. Or you could, you know, start with STAR-momentary as a base instead… which already works that way.
I probably won’t have time to mess with it for a while, but I wanted to make sure you were aware of it in case it might be useful.
I have the UI in post #913 working now, I’ll just have to play with the lockout function (probably start by copying from Baton) to get it to my liking.
I made a small add-on to star_momentary which dynamically changes the pwm level of the lowest moon mode depending on voltage.
Why?
Because I wanted a lowest moon mode (which is Phase corrected PWM level 2 when using 2 channel / a single 7135), and it doesn’t emit any light below cca 3.1V.
So I implemented a routine to up it to level 3 if the voltage goes below that level, so your light can always be able to work in the lowest available moon mode.
I did something similar in my cypreus firmware, where “moon” means “fast PWM=0”. It changes the PWM speed according to voltage, so that the moon mode will be less voltage-sensitive. At 4.2V it’ll run at the usual 19 kHz, but at 3.5V it pulses at 2.4 MHz. In-between it adjusts smoothly.
Below 3.5V it mostly just gets too dim to see, but that’s okay because the high-amperage cells I’m using are basically empty at that level anyway so I would need to change the battery.
If you find that changing the PWM level is too big of a jump, you could use PFM to adjust it more smoothly. However, this is incompatible with dual PWM so it won’t work on a driver such as the “moonlight special” with two independent PWM channels.
Yes, must be your company firewall. The code RMM posted was based on STAR_on_time v1.1 (pre dual-PWM). Yes, I expect that it should be simple to move the code over.
It’s a very simple mod. I think that LVP does not function when in strobe mode, but practically speaking I consider this more of a benefit than a risk. If you leave the light in strobe mode for an extended period you likely need the light to flicker more than you need to protect the battery…
Here is a link to the diff vs the original STAR_on_time v1.1 code (pre dual-PWM): Untitled diff - Diffchecker
The attiny13a can do two PWM channels or one PWM channel with a variable ceiling value. Not both. Since you’re already using two channels, you can’t change the ceiling. It uses the same register for both functions, but can only do one function at a time.
It would technically be possible to change modes when necessary, but it still can only change the ceiling on the primary PWM channel. The secondary channel is hardcoded to the highest ceiling value. So, it still doesn’t help, if your low modes are on the second channel.
Otherwise, if you’re curious I have a code example in both Ferrero_Rocher/Ramping_UI_table.c and in cypreus/cypreus.c .
I have an example of off-time FW with strobe in cypreus/cypreus.c in my code repo. Or an example with the new “noinit” off-time and fast strobe in s7/s7.c. But those both include a lot more than just a strobe; they’ve got all sorts of extra modes, and have diverged pretty far from their STAR origins.
Regardless, it demonstrates a way to add blinky modes.
hmm I looked at cypreus, but for some reason I thought it was a momentary FW. I might have to take another look. This is for someone else, it just needs L> M > H > Strobe
Yeah, it’s massive overkill for just four modes. It has, um, 15 modes. Or 18 depending on how they’re counted. Mostly, it just demonstrates one method of adding more stuff (like strobes) with an off-time clicky.
Hello guys,
I am working on the a17pzl driver and I would like to make a change in STAR off-time firmware that would enable me to set 255 pwm on secondary output for single 7135 and 0 pwm on primary output. I know that this change might create complications with stepdown battery monitoring and other functions but I am willing to comment them out for the ability to have the driver run 350mA on a single 7135 in one of the modes.
I am not sure what is the right and easiest way to do it. Any help would be appreciated.
Thanks.
you can take a look at star momentary firmware, there you can see how the second PWM output is used, it’s just a few more lines to be able to use the second PWM output.
In that FW, there is another array with PWM levels for the alternate PWM Channel, and for each flashlight mode you can set separately what the PWM levels are outputted at both channels.
Thank you vex_zg for a prompt reply. It seems more complicated than I thought. The momentary FW deals with modes a little differently and I am not sure how to adjust the off-time FW that I will be using.
