STAR Firmware by JonnyC - Source Code and Explanation
What would it take to add a fast strobe mode? Or is there already an off-time FW that includes a strobe?
EDIT: I see there are a few discussed earlier in the thread, but the links seem to be broken…? (Or maybe it’s my company’s firewall causing that)
Give post numbers please.
post #248 and on from there. That one sounds like on-time, I assume adapting it for off-time would just be copy/paste?
Yes, must be your company firewall. The code RMM posted was based on STAR_on_time v1.1 (pre dual-PWM). Yes, I expect that it should be simple to move the code over.
It’s a very simple mod. I think that LVP does not function when in strobe mode, but practically speaking I consider this more of a benefit than a risk. If you leave the light in strobe mode for an extended period you likely need the light to flicker more than you need to protect the battery…
Here is a link to the diff vs the original STAR_on_time v1.1 code (pre dual-PWM): Untitled diff - Diffchecker
thanks for that! now I can get it all set up while i’m still at work.
The attiny13a can do two PWM channels or one PWM channel with a variable ceiling value. Not both. Since you’re already using two channels, you can’t change the ceiling. It uses the same register for both functions, but can only do one function at a time.
It would technically be possible to change modes when necessary, but it still can only change the ceiling on the primary PWM channel. The secondary channel is hardcoded to the highest ceiling value. So, it still doesn’t help, if your low modes are on the second channel.
Otherwise, if you’re curious I have a code example in both Ferrero_Rocher/Ramping_UI_table.c and in cypreus/cypreus.c .
I have an example of off-time FW with strobe in cypreus/cypreus.c in my code repo. Or an example with the new “noinit” off-time and fast strobe in s7/s7.c. But those both include a lot more than just a strobe; they’ve got all sorts of extra modes, and have diverged pretty far from their STAR origins.
Regardless, it demonstrates a way to add blinky modes.
hmm I looked at cypreus, but for some reason I thought it was a momentary FW. I might have to take another look. This is for someone else, it just needs L> M > H > Strobe
Yeah, it’s massive overkill for just four modes. It has, um, 15 modes. Or 18 depending on how they’re counted. Mostly, it just demonstrates one method of adding more stuff (like strobes) with an off-time clicky.
Hello guys,
I am working on the a17pzl driver and I would like to make a change in STAR off-time firmware that would enable me to set 255 pwm on secondary output for single 7135 and 0 pwm on primary output. I know that this change might create complications with stepdown battery monitoring and other functions but I am willing to comment them out for the ability to have the driver run 350mA on a single 7135 in one of the modes.
I am not sure what is the right and easiest way to do it. Any help would be appreciated.
Thanks.
you can take a look at star momentary firmware, there you can see how the second PWM output is used, it’s just a few more lines to be able to use the second PWM output.
In that FW, there is another array with PWM levels for the alternate PWM Channel, and for each flashlight mode you can set separately what the PWM levels are outputted at both channels.
Thank you vex_zg for a prompt reply. It seems more complicated than I thought. The momentary FW deals with modes a little differently and I am not sure how to adjust the off-time FW that I will be using.
I plan to add secondary output to off-time capacitor reverse-clicky star firmware, within a week or two… I can share once I’m done…
I finally built a moonlight special test host tonight, and should be making a STAR derivative very soon with that sort of thing built in. I’ve been busier than I expected, but I’m getting there…
That would be excellent vex_zg and ToyKeeper. I am glad to hear that. Please share the code when you are done. Thank you
Well obviously I’m doing something wrong, I’m just too inexperienced to know what that is. I’m trying to integrate a strobe into Star off-time. Here is my full code.
Please post a diff against your most recent code which compiled correctly.
https://www.diffchecker.com/miv37pun
Your problem is here on line 381:
“else {”
You added an open bracket without a closing bracket. “else {do normal non-blinky flashlight stuff}” is the correct form.
EDIT: try just deleting “else {”.
I tried deleting it first, then also closing the bracket after the if statement, and it still gives the same error. AVRStudio says the error is in line 455.
