Me too Damn!
Well you two better hop to it then! Frequenting BLF and not even owning a Courui…for shame!
Is the quality still comparable on the latest big heads compared to when they came out? I just recently ordered a black Courui from gearbest so hoping it’s still as good as my first batch gray.
For me, the ‘early grey’ was almost identical to the ‘late black’. Of course, YMMV.
The only difference was that the stock pill from the black did not tighten down when flipped over, like some other members have also reported.
Please count me in - 32mm
Put me down for one for 20mm Sinkpad star.I will e mail when we reach 10 orders.
Ok people I need 2 more BigAmp lovers……
Finally, we fulfilled 10 orders, and so I want to let you know that I will start to make copper heat sinks on Wednesday, and all end up hope until Friday. Therefore, all who sign up please send me your name, address, zip code, and phone number. Those information send me on email nikola.stojsavljevic@gmail.com or Viber +38166301302. After I receive your contacts, i will send pictures of finished product and my bank eban number for paying. When I confirm payment, orders will be sent ……
So thank,you guys for patients and see you soon
LIST OF INTERESTED MEMBERS
1. dodo – flat top
2. Werner – 32mm
3. DBCstm – 20mm
4. LinusHofmann – 20mm
5. dbramm22 - 22mm
6. zeremefico – 32mm
7. prisma –32mm
8. BillyX – 20mm
9. Caleb-V – 32 mm X 2
10. Nicolass - 32mm X 2
I will be happy if you drill holes for wires if it will match the 31.5mm maxtorch XML mcpcb
Ok Caleb-v no problem
Same here please
hi
great pill from what i can see, this is so tempting that now i see for a good price for courui. damn i have to resist :bigsmile:
Please put me down for two pills; both for a 32mm MCPCB (gotta love those big Maxtoch dtp MCPCB’s), thanks!
—> this goes for me to: I will be happy if you drill holes for wires if it will match the 31.5mm maxtorch XML mcpcb
Nico
Amsterdam
Great workmanship and price ... unfortunately I do not own a Courui.
Me neither, but I’m gonna buy one now! :bigsmile:
I always liked them, except for the shitty aluminum pill and the fact that the cells are parallel.
Nico
Nico, think of the Courui as a well built thrower that houses a 7500mAh cell.
I’ll be putting a Luminus SBT-70 in mine with an FET driver, pulling in the 10-12A range most likely. Those 3 parallel cells are EVERYTHING!
I’ll be watching closely how that turns out.
I ended up getting 2 sbt-70s (was basically buy 1 get one free because of shipping) so if that turns out well (I’m sure it will) then my “stock” courui may become the home of the second emitter.
Paired with the gorgeous Courui reflector seems like a good match!
If all goes well, I won’t be using the reflector at all. Working on something else that promises to allow the SBT-70 to throw over 1200M. If I can pull it off it’ll be unique if nothing else. lol
If it’s still possible, I’d like mine made to fit a MaxToch 26 mm star please. The wire holes are at 22-22.3mm. The actual diameter of the star is 25.7mm, 26mm will work fine.
Thank you very much, sorry for the change.
Can I have wire holes 25mm apart please.I will PM you with my coordinates now.
So contact info sent and viber installed.
Do you need the measurements of the maxtoch 32mm star?
