What a great photo. Those SBT’s look like high tech works of art.
Slightly different lens/emitter ratio and focal length between these two lights , but I’ll stay optimistic that I’ll acually be able to see the thing in there when it’s done, would be nice.
The SBT70 in my TS2010, with a freshly charged King Kong 26700 5000mAh cell, pulls 9.23A.
This is one of the early BLF fet drivers, and it’s sitting on Ryans copper pill, a pretty healthy chunk of copper.
Interesting, would have thought it might pull more DD, but there’s too many variables at play to really know what’s going on in a light.
Has anyone anywhere done any testing on this emitter to see how far it can be pushed? If not I’ll try do a few safe-range tests to see how it responds. Curious to see if the vF stated in the datasheet is accurate.
A Sony C5 18650 allows 10.02A
What bin SBT70 do u guys prefer ?
The 5700K variant would be the one.
Thanks Dale first thing i will try mine on is the 4" double aspheric lens i have :)
All this talk of this gorgeous emitter and I had to look it up at Mouser. They happen to have em in stock in the 5700K version for less than I’ve seen em ever, end of life they say! So I ordered one. The wife will kill me over this stuff some day…
Dale can u send me the link ?
Now, they’re still not what anyone would call cheap. Just cheaper than they were!
Thanks I though they had a 2000LM bin anyone try those ?
Forward voltage at 9A with the King Kong is 3.33Vf. Crazy huh?
Oi! don’t you all go buying up these beauties before I get a chance to grab one!
I don’t think you’ll get anywhere near a 2000lm Bin out of it unless you go for the CW variant. The NW 5700k seems to be around 1200 at best from what I’ve seen.
Like Dale said these things ain’t that efficient!
The super cool 7000k tint bin numbers give a spewed idea of what these emitters really produce, any XMLs I get that are so blue (low 1A/0D equivalent) usually wander straight into my bin
Yep, this aint an XML2 that’s for sure!
This is good, it means it’ll run on an 18350 without any problem. That’s my alternate plan. My main goal is to try something that hasn’t been done before. Having trouble obtaining a part, MOQ is 20 pieces at some $660! The alternate plan is looking more and more like the main plan. lol
Well I got a big :bigsmile: on my face today, the SBT-70s arrived!
Just amazing looking emitters.
And a surprisingly small die area. Looks to be somewhere between the apparent die size of a domed and dedomed XML. Closer to a domed Xp-g2 than I thought, and of course the mt-g2 looks like a hulking beast in comparison
And finally, something that looks like it comes straight out of Tron!
This is really interesting actually. The blue leaks out at the edges to give this interesting looking effect. Wonder if this will be visible in the projected image? Maybe I need to stick a blackout window to the emitter “window” to keep the image perfectly clean and round. Could get interesting.
That pic looks sweet, cant wait to see some beam shots
I surely do love how this one looks! Mine is still in it’s little fancy foam padded box.
I can’t wait to see the color of light it produces. Daylight white at 5700K and 90CRI, been dreaming of this one for a long time now. The one I have in my TangsFire 2010 is blue-white, obviously a cooler tint. But that defined circular hot spot is too nice, even in the 2010.
Sure wish I could afford 3 of these to do a triple with. :bigsmile:
You do know, of course, that the dome on those Cree emitters magnifies the die. This one has no such magnification, you’re looking right at the die itself. Peel the dome off that lurking giant (MT-G2) and you’ll find it’s not really much larger and made up of like 84 tiny dies in an array. Still no comparison. And the de-domed XM-L2 is tiny next to this beaut.
I need to get a macro shot like that one of yours Linus, I’ll make a desktop background of it. Care to send me a link to the high res version of yours?
Pure decadence! :money_mouth_face:
And yes of course the domes make a massive difference to the apparent size of the die. But that’s what I was trying to say, I expected the bare die of the sbt-70 to be larger than the apparent die size of a domed XML. Surprised that it was smaller. Just in terms of comparison and predicting how it may throw. If that makes any more sense at all…hehe. Opening them up I was just “hey these dies are quite small, nice!”.
It’s probably the massive pcb they come on that makes them look smaller than they are!
Sure I can send you the photo, but it’s not a particularly amazing shot. Was rushing and the closeups are under terrible led lighting so the golds don’t “pop” as they should.
I’m sure I won’t be able to resist doing a better photo session with those emitters soon.
Edit:
Here’s a slightly tweaked version showing the bond wires up close. It really is a work of art this thing.
