Ultrafire F13 at $11.39 - with Coupon Code - Gearbest
Thank you again gentlemen :slight_smile:
> resistor removal brings the unit from 5 modes to 4
Wait, what? Is there a choice of which of the five to get rid of? Like, the SOS mode, preferably?
With the resistor taken off, it changes to H/M/Strobe/SOS. Can't get rid of strobe or SOS on this particular driver. At least, not on the four I had.
Thanks everyone for info on this light.
Seems a good deal even for a noob who will likely not do any mods on it? (may be exception of thermal paste).
Thinking about just plug and play cheap and reliable light. And I love the convoy S2. Would this light compare well to the convoy S2?
Not really. The S2 is better machined, better assembled, and has a much better driver.
I would not call this either “plug and play” or “reliable”. It’s a nice inexpensive mod host and playground in this form factor.
Mine has been working reliably. I only added heat sink compound today. The fit and finish of mine is very good. It uses resistors instead of current regulator chips to control the current, but that is not a serious problem unless you want very high output. I expect to retire it soon, only because it is not a zoomy. I don’t have a Convoy to compare it to, or intend to get one.
Thank you for quick reply. I will look else where such as “roche-f6”.
Cheers
Not the same type of platform, the F13 is more like the C8, the S2 is a slimmer EDC style more floody than throwy type light (shorter thinner reflector unlike the C8 or F13 wide long reflector)
Have you tried the spring bypass yet for more current? (aka soldering braid wick or a 22ga or thicker wire from the top of the spring to the bottom of the spring for better current flow)
I received a prompt response and promise of a replacement XML2 F13 for the XML-T6 I received.
Thanks OL!
I modded the XML-T6 per your posts (braided springs, moved + wire, sanded down reflector spacer, etc)
Now it rocks!!
:slight_smile:
I have bought like 14x from this light
Quick question on this (to OL or anyone); I’ve haven’t yet gotten into any modding, though it sounds interesting and a lot of fun. Do all lights need this thermal paste or just certain ones? For example, I have lights like the Sipik SK68 and SK98 as well as the TF A8 and now the F13’s are on the way (as well as various no-name lights from different sources). Would it be advisable to put thermal paste on all of these types of CREE LED lights? And if so, is there a good instructional vid to look at to know where and how much and any other tips and tricks? This sounds like something that I need to learn to do but want to learn to do it right.
Thank you :slight_smile:
Thx OL! Just ordered 1. $9 bucks and you can’t go wrong!!
Paste is an absolute must. The thinner the layer, the better. Most lights come with it already… you’d be able to see a white-ish paste oozing out from under the star if there’s enough there. Dunno about videos, but just be sure you don’t let the reflector short out the leads going to the star when you reassemble.
For more information look into CPU heatsinks in the PC community, but ruffles has really covered all your bases already.
One way to apply a grease type TIM (thermal interface material) is this:
Okay, thank you both. Looks like I’ll have a little project to do with my lights.
Received both of the F13’s I ordered in the OP. That was 18 days in transit which isn’t that bad. It comes with an 18650 sleeve and a 3xAAA holder which is nice to have those two items included. I tested both out with a Trustfire Flame 26650. The hot spot is tighter than the A8 that I have so it puts a bit more light into a smaller more focused area. The spill isn’t quite as bright as the A8 but still quite bright. What this means is the throw seems to be even farther than the A8 while the overall lumens looks to be similar. I have no way to measure lumens but it is easily as bright as the A8 overall. The O-ring is glow-in-the-dark which is also a nice feature.
Overall it is a really nice light and for $9 an incredible deal. It is slightly larger in length than the A8 and the front have is larger in diameter. I’ll probably still carry the A8 as my primary deep woods light, but it will be a hard choice. The determining factor may be if it fits in the zippered pouch on top of my hiking bag or not. But it will make an outstanding back up.
I really appreciate the heads up on this deal, thanks OL :slight_smile:
For a $9 light you might as well do the ‘standard’ mods at least. (Move LED+ wire, pencil the capacitor, and bypass the springs if you’re feeling daring.) That might tip the balance. :wink:
I have to say I am impressed with the customer service at Gearbest. They sent the wrong model (XML-T6) I contacted customer services to tell them, they said keep it and we will send the correct one out and today it arrived with the correct XML2, not sure what bin definitely cool white but much nicer than the blue white of the XML and as a bonus a bit brighter.
Very good service that I would say and I will use them again after this :slight_smile:
Just ordered 2 more… surprisingly the code is still working… now just hope they send me the XM-L2 version :stuck_out_tongue:
