You can see the archived poll results on the Wayback Machine:
https://web.archive.org/web/20221220093741/https://budgetlightforum.com/t/-/72677
ok, first of all,let's choose the host.
1.Convoy S2+ with some better knurling.
2.S2+ with an extend tube for 18650.
3.AAA host. (maybe a finished one?)
4.Other suggestions?
3 days available for this poll. I will get a sample of the chosen one and ship it to factory for drawing.
how about a small convoy, with an optional 18650 tube, or visa versa?
Edit: how about a 3rd tube: 18500?
Is this light going to be made of titanium? What do you mean by S2+ with extend tube? Do you mean an 18350 light with an extension for 18650 or do you mean an 18650 light with extension for two 18650s?
I would love an s2+ Ti with interchangeable battery tubes in order to utilize either 18350 or 18650 batteries.
That would seem truly ideal for me
I think the A60 with aluminum reflector optimized for XM-L2 would be a real winner!
At one point there was a lot of backing for 18500. Is that what is meant by βConvoy S2+ (with 18650 ext tube)β
As it is custom built (either with a choice of tubes, head and tail are the same and X number of βbodiesβ are availible) or as (18500 and we can get an extender)?
This is the 18350/16340 version.Tube in the middle. make it a longer one to fit 18650.
I might be more interested in a solution for 2x18650 with an S2+.
Dangerous, which were you actually more interested in?
Convoy L2 with aluminum reflector optimized for XHP50 or XHP70.
As nice as the Convoy L2 is, I doubt there will be 200+ people shelling out for a Ti version.
As mentioned i the other thread, I prefer the S2 over the S2+ because it has the IMO better, deeper reflector.
As long as all of the threading is the same as the S series, so as the tubes/tail/internals can be interchanged, Iβll be happy.
djozz: Define 'better'... In principle a deeper reflector has slightly more throw, but probably not with OP. It does have slightly less flux output (lm) due to the higher fraction of reflected light and reflection losses. Thr biggest difference is the smaller spill angle which I personally am not happy with in an EDC.
See #112 https://budgetlightforum.com/t/-/11947?page=3#comment-715462
Sorry, I agree that 'better' is not appropriate in this case, I should have said: 'different' and more to my liking. I prefer the narrower spill area and wider hotspot (of ~equal brightness) that the deeper reflector provides compared to the shallow one.
AA (14500 if you must) light, less material for lower cost and a common form factor (and most everyone has eneloops)
My vote would still have been for an 18500 light ββ because you canβt buy one elsewhere and itβd make it a lovely unique high performance light.
The thing to remember is, this was muted as a host only β which means each of us will need to source the rest of the components to complete it.
The AA form factor is just so limiting in terms of drivers, stars, optics, reflectors and switches. That it no longer is a self assemble DIY host, but a custom build that will require you to compromise or spend loads or both.
Having a host that supports 16mm stars and 17mm drivers is in my opinion essential. This physical size means widely available reflectors, optics and switches are also easy to buy.
So my view still stands, make this an AA light, but make it big enough to support the above points/specs. Which means it would be an 18500 light.
An 18500 size would allow:
-AA to fit (maybe with an easy to make plastic insert to prevent rattling. Springs at driver/switch may solve this anyhow.
β14500 support
β18350 support (small spacer, easy/cheap to make)
β16340 support
β18500 support
So it would be an AA light, but so much more.
No other batter format will offer this versatility.
I'd like more bling! Something more special. Convoy is a nice light, but can't understand the appeal for it in titanium.
So I chose "other".
I think Rey is going to use the Convoy for the machinist to measure all sizes and internals. The looks on the outside are by no means necessarily going to be Convoy style.
