djozz: Define 'better'... In principle a deeper reflector has slightly more throw, but probably not with OP. It does have slightly less flux output (lm) due to the higher fraction of reflected light and reflection losses. Thr biggest difference is the smaller spill angle which I personally am not happy with in an EDC.
See #112 https://budgetlightforum.com/t/-/11947?page=3#comment-715462
Sorry, I agree that 'better' is not appropriate in this case, I should have said: 'different' and more to my liking. I prefer the narrower spill area and wider hotspot (of ~equal brightness) that the deeper reflector provides compared to the shallow one.
The thing to remember is, this was muted as a host only — which means each of us will need to source the rest of the components to complete it.
The AA form factor is just so limiting in terms of drivers, stars, optics, reflectors and switches. That it no longer is a self assemble DIY host, but a custom build that will require you to compromise or spend loads or both.
Having a host that supports 16mm stars and 17mm drivers is in my opinion essential. This physical size means widely available reflectors, optics and switches are also easy to buy.
So my view still stands, make this an AA light, but make it big enough to support the above points/specs. Which means it would be an 18500 light.
An 18500 size would allow:
-AA to fit (maybe with an easy to make plastic insert to prevent rattling. Springs at driver/switch may solve this anyhow.
–14500 support
–18350 support (small spacer, easy/cheap to make)
–16340 support
–18500 support
So it would be an AA light, but so much more.
No other batter format will offer this versatility.
I think Rey is going to use the Convoy for the machinist to measure all sizes and internals. The looks on the outside are by no means necessarily going to be Convoy style.
I think the S2+ ti version with enhanced looks/features is a good idea. I voted for 18350 but would be okay if 18500 or 18650 or such is the choice. A combo with 18350 and 18650 would be nice too. Also, a request for triple compatible pills or spacers?
AA or AA would be my preference. I am getting less happy having potential ‘mini bomb’ batteries in my house every time I read a horror story on here.
AA or AAA battery sizes are a no brainer if you live in the UK really, it’s all we can get without going international, they are always in the drawer and if not you can buy them from the shops.
Maximum power is not always the top priority. I have a LED Lenser® P3 BM, and for it’s size it’s fantastic.
[/quote]
Yes,just need the inner size of S2+,so everybody can mod or complete it easily.
