JonnyC was working on this; look at the MTN_momentary_temp version of STAR. It’s written for e-switches instead of off-time clicky, but it should at least demonstrate how.
The difficult part is that the attiny13a can only process one ADC reading at a time, so you have to keep switching the ADC channel between voltage and temperature. And you’ll most likely need different code to respond to each, since one steps down as values get lower low while the other steps down as values get higher. Also, one can step back up while the other never does.
You probably won’t need much of the solder star configuration code either, since you’ll have a maximum of one star available after connecting the OTC and temp monitor. Add an e-switch or second PWM channel or indicator LED, and then there are no pins available for stars.
Ah cool, thanks for the tip. I’ll look through that version to see how it’s done, and maybe I can understand it enough to transplant a few code snippets
Cheers
Thanks, yes this would be used on a 2s driver running a 5v LDO so operation voltage isn’t a concern. Thanks for posting the alternative for 1s though, didn’t know about that one
The starry-offtime firmware now has additional features:
3-level offtime support, so you can go both forward and backward through the modes
10Hz tactical strobe mode
battery check mode (also functions as a beacon)
It has some early code for hidden modes too, but it’s not working yet. Currently, it just tacks them on to the end of the regular modes, and they’re not hidden. I may branch before finishing that though, because I ran out of room and will need to remove some STAR bits before I can add new things. If I do, it won’t look much like STAR any more.
I’m mentioning this because it adds some things people asked for. Basically, STAR_offtime with individual control over each PWM channel, bidirectional mode switching, strobe, and battery check.
Oh, um, the battery check code is currently calibrated for RMM’s Moonlight Special driver, which seems to get higher readings than any other driver I’ve tested (nanjg, BLF17DD). It may be a little “off” on other drivers unless you recalibrate it.
My measurements are in the ToyKeeper/battcheck/ directory, along with a firmware which can be used for making new measurements.
RMM may have switched to a protection diode with lower forward voltage (eg voltage drop). Does the diode on your Moonlight Special have a marking on it? (like 41 or E2)
Indeed. On the Ferrero Rocher, I see one labelled 41. On the Moonlight Special, it’s labelled E2. The ADC readings between the two differ by about 10, which is enough to make LVP and battery charge estimations not work well.
Hi guys,
First time im posting in your forum but its been a while that i read your stuff. Pretty amazing what you have done with this little nanjg-105c. Tido, JohnnyC , drJones and all other programmer could be proud of yourself!
I have programmed around 20 drivers (nagj-105c with 4 stars)with your technics but some fails . Let me explain!
First , i modified the code by simply add more Modes to the star mom like 1,8,14,100,255 . 90% of the Times everything work the way it should. But some refuse to get 5 mode even if i reflash several times. It only work on 4 modes with the turbo in??? Any idea what could go wrong.
After i got one that the turbo is really fast even if i programmed it to 60 sec? is duration is around 10 sec? reflashing and it change nothing any idea whats happening here
The problem is likely your mode level setting of "1". That is far too low for most 7135 chips to turn on, especially when there are multiple 7135 chips on the same board. Depending on the number and type of 7135 chips, you probably need the lowest level to be between 6 and 8.
The turbo timer on the momentary driver is set in 0.016 second increments. So for 60 seconds you would need to enter a value of 3750 for the timer (60/0.016).
Thanks for your reply,
i changed the code for the two driver that have only 4 mode and now is working with 6 modes… ill removed one entry and i should end up with 5 mode problem solved tks!
for the timer… that one i really don’t know what to do with. I changed the number of ticks to 10000 ! so more than 120 seconds and its not responding… 5 sec on and it change to the previous mode , really strange!. All other driver( more than 20!) work perfectly with turbo but only one is not working??? Ill work on it but i think it will end up as a 7135 chips spare parts!
Anyone have a idea what could go wrong with the timer?
I wonder if you are seeing the low voltage protection kick in on that driver. If it steps down from any mode other than the highest mode, then that is probably the case.
Because I'll be running an ATtiny13A from a regulated voltage, would it be better to switch the ADC Vref to Vcc rather than the Internal reference?
It seems like this would allow finer control of battery voltage monitoring. Of course the resistors will still be across the battery and the values will need to be tweaked.
Do I only need to change the REFS0 bit in the ADMUX register and adjust the low voltage stepdown values? Or is it even worth the bother?
Looks like changing that bit is all you need to do to change Vref, but I haven’t tried it myself. If you’re using an off time cap you’ll have to make a few more changes though.
I didn't think about that... I have figured that too much capacitance on the output of the regulator will affect the click times, may have to add a bleeder resistor to hasten the discharge. But this will (slightly) increase current draw with no benefit to the LED current. Not a big deal for big batteries.
Regardless of actual battery voltage (tried varying it with lab PSU), I always end up as ADCH=128 and ADCL between 106 to 110.
Don’t know what to try next. The ADC routine is the standard one from Star_offtime. Went through datasheet, seems everything is the same as with tiny13a, but I’m no expert in uC programming.
Hey guys, I’m looking at doing a dual PWM build but I’m wondering, does the alternate PWM output stay on once it get’s to the set-point above and if so, what would be the best way to turn it off, so it’s only one or the other outputs? I’m wanting to make it so moonlight is a separate emitter (and it’s own 7135) and that emitter turns off above moonlight.
