Test/Review of LG 18650 HD2 2000mAh (Magenta)
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 20 hours ago
DSC_8628
Official specifications:
  • Nominal Capacity: 2000mAh
  • Nominal voltage: 3.65V
  • Charging methode: Constant current, constant voltage
  • Charging voltage: 4.2V
  • Charging current: 1000mA
  • Charging current cut off: 50mA
  • Fast charge: 4000mAh
  • Fast charging current cut off: 100mA
  • Standard discharge: 400mA
  • Fast discharge: 1000mA, 20000mA
  • End voltage: 2.5V
  • Ambient temperature: Charge: 0~+50°C, Discharge: -20~+70°C
  • Weight (max): 48g
  • Dimensions (max): D: 18.5mm, H: 65.2mm
LG%2018650%20HD2%202000mAh%20(Magenta)-info
This is an high current cell.
DSC_8627
DSC_8629 DSC_8630
DSC_8631
DSC_8632
DSC_8633
The supplied has added a strip with specifications on top of the type number (It can be peeled off).
LG%2018650%20HD2%202000mAh%20(Magenta)-Capacity
The cell is rated for up to 20A discharge and it has fairly constant capacity up to 20A.
LG%2018650%20HD2%202000mAh%20(Magenta)-CapacityTimeHours
LG%2018650%20HD2%202000mAh%20(Magenta)-Energy
LG%2018650%20HD2%202000mAh%20(Magenta)-PowerLoadTime
LG%2018650%20HD2%202000mAh%20(Magenta)-TripCurrent
LG%2018650%20HD2%202000mAh%20(Magenta)-Charge
Conclusion
The cell is not the top current and capacity cell, but it has fairly good performance and being from LG it is a good cell.
Notes and links
Compare to 18650 and other batteries
Calmaja
Last seen: 2 years 5 months ago
Thanks HKJ. A little late by LG, looks like not better than Sony VTC4, hoping they progress at faster pace.
HKJ
HKJ's picture
LG has other cells that are better at high current and capacity.
dangerous
dangerous's picture
Last seen: 6 years 11 months ago
LG HE4 would be a better competitor to the VTC cells, but won’t match the VTC5.
BLF
Calmaja
Really sorry, I forget about HE2, HE4 Blushing
Ironically, I type it based on this figure Shocked
