They took my $3.
It says “Product Size:L120mm x W20mm x H20mm”. 120 mm. is rather long for a compact 18650 and 20 mm. is only 2 mm. wider than the battery.
There were 15 in stock 7 hrs. ago after I bought 6. Great deal, thanks. If ordering several the standard shipping becomes less than the super saver shipping. After VIP discount, coupon, and shipping upgrade.... $14.10. $2.25ea.!
I would assume that it probably won’t be driven very hard. Hopefully the driver can be resistor modded. IMO it would be easier to upgrade the LED to a XPL so that the same centering ring can be used and it will fit without modification.
The MyLed S7 model is a legit Supfire. Threaded aluminum pill with a shelf. Still waiting on the S5 it’s in transit. I believe the only difference between the S5 and the S7 … is that you can use 3 aaa’s or an 18650 in the S7. S5 18650 only.
