I currently keychain carry a ThruNite Titanium AAA light (Christmas Edition XML) running an Energizer Lithium. This recently replaced a 4Sevens Preon ReVO which I carried everyday for about 4 years and was still working perfectly, just looking severely worn and it had a damaged reflector (I believe from water intrusion when I accidentally took it to 100 feet scuba diving…)
I generally also EDC an Eagletac D25A Ti XML2, powered by a Trustfire 14500, clipped inside my front pants pocket or the small “ticket” pocket if I’m wearing jeans. In my job I frequently leave my keychain in my bag, and the Eagletac becomes my only light. It gets a lot of use, for me having a small, instantly accessible clicky that starts in low is extremely handy, and with the 14500 it’ll go very bright if need be. The keychain light is less handy, so it gets less use, which is why I run it on a primary, not a rechargeable.
Neither of these are really “budget” lights but for my EDC I really appreciate a bit of Titanium bling and resistance to getting banged up.
I carry a 18650 Convoy S8 with a black Titanium coated Fenix PD35 clip, black tailcap boot, triple XP-L and BLF17DD driver, solid copper spacer, and a Carlco 10511 optic.
I wanted the most light possible in a “tube” 18650 format, and triple XP-L is the way to go for that! I like the Convoy brand in general, and the clip placement on the S8 is just perfect for me: leaves just enough of the light poking out of my pocket to grab.
I’ve been carrying the host for about six months, but I just put the triple in it about a week ago. Before that it had an XP-L V5 3D at 3 amps.
I generally use it 3-4 times a day, depending on what I’m doing that day.
Works great, I love it! The only complaint that I have is that there is audible PWM on modes 3, 4, and 5 of the 6-mode STAR firmware that RMM flashed his Direct Drive drivers with before he got guppydrv. Oh, and there is just a hint of green in the tint, but that tends to happen when you dedome LED’s (to fit under the XP optic)…
The finish is holding up beautifully, but it doesn’t get tossed around much, since it is clipped to my pocket all day.
At some point, I plan on getting a good AAA/10440 light to carry as a backup, probably the Thrunite Ti3, but I haven’t gotten one yet.
DQG AAA clicky NW
Is it a AA or AAA or lion? AAA, should be 10440 too
Why’d you choose that one? Stainless steel, small, NW, clicky
How long have you been carrying it? 2-3 months?
How often do you use it? daily
How’s it working for you? great, with the exception that it doesn’t work with LiIon. waiting for a replacement
How’s the wear-n-tear on the finish? great, main reason for searching for SS
Do you carry more than one? just one
The one I mostly use is on my key chain. It is currently a Smiling Shark SS-5039, with an Efest 10440, a pill made from a copper pipe, a BLF Tiny 10 driver with 3 x 7135 current regulator chips and a Nanjg 105c two group controller with hidden flashy modes, and a neutral white XP-G. Smiling Shark SS-5039 1 x AAA size flashlight, modification notes, Now 3 x 7135 with modes, on a BLF Tiny 10 board. post #107 and following. I will probably go back to the driverless twisty some time.
Why’d you choose that one? Very bright, looks and feels good, regulated, two mode groups / Very small and light, good pocket clip, three modes, red, somewhat moisture resistant
How long have you been carrying it? 3 months / 10 years
How often do you use it? Twice a day / Every week
How’s it working for you? No problems / Replaced one that started to malfunction and one that got lost
How’s the wear-n-tear on the finish? The anodizing wears off at the edges. / Some of the rubber switch boot tore.
I use an Inova with the coin batteries with my keys and when its dead it will be replaced with a nitecore tube, the tube will be the best light for a keyring for a long time.
Olight i3s w 10440, not on keys, just loose in pocket with change and a Gerber Sportster, every day since I bought it replacing an SK68 clone on a 14500.
My only concern is that I only use unprotected 10440 lions, but so far the output droops fast as the lion discharges so I notice and recharge.
forgot to tell, since last week I started carrying a Lumintop Tool in the small front pocket of my jeans as an extra backup light. It has a standard alkaleak AAA battery and I modded it with a 3500K 80CRI LuxeonQ.
Now carrying Lumintop Tool (AAA):
Very compact, grippy knurling, good output, simple UI, not easy to accidentally turn on, loud clickie button, cool tint (which I don’t like, but it’s acceptable), runtime dictated by battery type (not much).
Previously carrying Zebralight SC51W:
Brighter, throwier, longer lasting, better tint, cool UI with direct access to moonlight or high, BUT… bulkier and easy to turn on accidentally, which brought to the need to perform lockout everytime and defeated the purpose of one-handed operation.
Looking forward to try: EagleTac D25AAA and L3 illumination L10 or L10C.
In the pocket: Ultrafire C3 SS (XR-E led), mod with DX 25505 driver and forward switch. Eneloop 1st gen.
In keychain: Bronte RA01 SS. Sony CycleEnergy (LSD)
UI rocks!, huge lumens for its size, programmable light levels
every day since I bought it, about 18 months
almost daily
fantastic!
what wear and tear :-)
Not on a daily basis unless I know there is a need for lots of lumens for a long time.
I'm hoping that the new groupbuy of the EE A6 will convince me to swap the SC52w out of rotation. The sc52 has a great clip that I use to attach it to the top of my jeans pocket. Using that clip the light never moves and I've got no fears of losing it. The other thing I will mention is that the sc51 had an issue with accidental activation's, that is fixed in the sc52 with a more recessed button. Not a cheap light but certainly a keeper.
Nitecore Tube modded by Vinh on my keychain, and SC52w also in my pocket.
The SC52w is perfectly covered by Mr.Muller in the post above... after a lot of use, and some abuse only sign that it's a used flashlight is some very small wear on the sharper edges... still looks 95% like new. Have two of them and love the fact that I can can pop in a AA should the 14500 run out.
About the Nitecore TubeVn... modded to higher output, I haven't used it much, but it's bright, very very floody as expected, and can take a beating. Main reason I've switched to it is that it's micro usb rechargeable. Haven't run down the battery completely yet.
Ultrafire SK68 clone in cargo pants
AA and 14500 - one in the light and one in pocket.
Small, cheap, tailstands, strong clip, zoomie is versatile, single mode with variable light by switching cells.
Carrying it over a year.
Used 1-2 times a day - lend it out occasionally.
Been working great.
Anodizing is worn on a few places - I baked it for an orange finish.
No - cell phone is backup light. When home, carry P60 or C8 in jacket pocket in the evenings.
I was carrying a P60 light for awhile, but found it was a bit too big, and having to explain modes when lending out was a bit of a pain. LOL No one else I work with carries a light, so it get’s a bit of use. Mostly indoor stuff. Most are surprised it only cost $3… Nice flood for close up and it throws surprisingly well when zoomed on a 14500.
Works for me!
I carry a Sipik SK68 as well in my EDC sling bag along with a Maglite XL50. I agree that for the price it’s an awesome light. Hard to believe the price you can buy them at. Just ordered 10 of them off Amazon for $3.33.
You mentioned you baked the light to get an orange finish, how did you do that? And do you have any pics?
Should show in my avatar/profile pic. Disassembled it and put in the oven at it’s highest temp and kept an eye on it - took somewhere around 45 min it I remember correctly. There are some threads on baking lights…
EDIT: Here is a thread on baking: What's for dinner? Baked UltraFire!!
Not to hijack but here's pic of one I did couple years back in toaster oven. Just watch it til it gets the color you want then remove from oven. Don't forget to remove all pieces that heat will damage !!!
