Copper triple p60 shells (run 2)
Pm sent Xandre. Thanks.
Paypal send. Thanks
I’ve been looking at these for a while now, and been thinking if I should add one of these to the ‘collection’. I have Solarforce L2, N, T, and P and was wondering how well these would work in those lights. I know very little about these copper drop ins and their performance. How much better are they? Is it just esthetics?
These dropin shells will fit all of those hosts and many many more. They are pretty universal.
If you plan on running a dropin at full power, 6-9 or more amps These are amazing. At conservative power levels there’s not much out there that will beat solid copper.
There is very little thermal sag and the led stays cooler longer.
You will still have to add a small piece of foil to the biggest part of the dropin for a snug fit.
I ran a nichia 219b triple in my hand at 4.5 amps for over 5 minutes and the shell was getting warm but not by any means hot.
In my opinion these are the cats ass for triples. At least high powered triples. They also fit everything needed perfectly.
(edit) I was wondering the same things when I first ordered the others from mattaus. Once they arrived I knew I needed to have more.
I got my yesterday.
Perfect Art.
Thanks very much.
Regards Xandre
WOW! Absolutely gorgeous. These things look like the answer for the P60 triples. Very nice work
Glad you like it Xandre. Thanks for letting me know it arrived.
Jeremy
PM sent.
Just got mine and I really love it.
Too bad they are all gone. Let me know if you have any more in the future. Thanks
Hi everyone, I’ve been crazy busy with work, sickness and a very late spring (still isn’t here)
I’ve had these almost two weeks and if there’s still interested people I have 40 available.
If you’d like completed triples I’ll be updating my p60 build thread in the coming weeks. I’ve got a couple of projects I’m working on right now so the dropin factory will remain closed for a bit longer.
Jeremy
could you make a completed ready to use triple nichia 219a drop in or does it have to be a B?,
It’s for a solarforce L2D side switch flashlight where I believe the tail can take 3A right?.
Is that ok?.
I’m in london.
Thanks.
I could do either, there’s also a few more questions I’d need answers to. Modes, optic type, current/mode power etc.
Would it be possible that I send you message in two-three weeks? I’m really quite busy at the moment with work and a couple of other builds.
Hi Bushwhacked
I’ll like to order 4 of your copper P60 shells. Is the price still the same as the previous batch at $40 for the first one and $30 each after the first?
Thanks
With all the talk about Noctigon Meteor M43 I suddenly have a craving for a Triple light. I just might go for a P60 Triple. :slight_smile:
Thanks yes PM me .
are these tapped for the Noctigon screws or is it best to solder it in? also how is the driver mounted in these? thx
not tapped, and the driver drops in and would need to be soldered or placed with adhesive.
Are these still available?
I would be interested in a couple if they are available?
Same, are these available?
