I have not been bothered by that portion of the clip . I always clip these to the outside of a pants pocket and haven't ever snagged it on anything . I suppose you could bend the tab of the clip easily enough if it protruded too much for your tastes .
When I got these clips , they were too tight . I had to drive them onto the edge of a hatchet to loosen them up to a 1/16" gap .
When I am wearing my S2 with it's deep carry clip , it binds a little sometimes when I am seated .
The suspension clip adds a ' hinge ' that makes it more comfortable . By the way , the 'oval' split rings that come with these clips are ideal . The oval nature allows the clip to be more easily threaded into small spaces .
Would you be better served by clipping to the inside of a pants pocket? Not sure I'd feel comfy having an external " dangler" .
Clipping to the inside would serve to protect torch while it would be inside the pocket and also keep the torch from accumulating fluff from the bottom of the pockets. Would also protect from abrasions with other objects in there as well.
I noticed those when I went to the op’s link, those look real nice and a good price and 316 stainless to boot, I’m gettin some on my next order. Sorry for off topic.
Another option if you have a drill is to use the handle of a teaspoon suitably bent and drilled to take a split ring.
BTW the oval shaped split rings are available in a set from EDCGear.co.uk in the TEC Accessories: Split Ring Kit 2 no doubt they will be available in other countries as well TEC is a well known name.
The oval split rings fit the pocket better having less width to “print” on the outside and a more comfortable carry.
Any other split rings I buy from ebay or Amazon.
No reason not to put the split ring on the bent out portion and have the straight part outside your pocket if you’re bothered about it catching on something or marking paintwork etc.
Very nice. It also looks like you could put the split ring at the bend in the clip so the clip and the light would sit parallel in the pocket and not as deep. I have some small lobster claws from ChicagoX as well as a few of the mini biners from Hank but that clip looks like a nice alternative.
