i wonder what it would be like in my Z1… i wish i had a source for just the brass pill out of the z1. i would build a few different set ups for it.
As OL said, yup, and you can also use a Zener mod driver for the xhp 50 on XM mcpcb’s for a tighter beam or where you want to use a reflector/optic with a smaller opening. Good thread, I have 50 on the way I can compare to an mtg in the same Fastech 35mm reflector.
subbed and will update soon.
It would be horrible, throw would be not good (for the amount of power) and there would be dark lines in the projected image cause of the multi-die emitter.
i know it would be like that, but what about partially zoomed? and i know exactly what you mean about the lines
Part 2 with a lot of help from an army of willing assistants of which a couple deserve an honorable mention. Lucy and Jack. I just wish they could use Photoshop quicker and more adeptly than I can.
Applause for the two main assistants as they really pushed me to my limit like I was a dog.
All pictures with mouse overs will have the MTG-2 mouse out with the XHP70 as the mouse over.
Firstly will be zoomed out and secondly zoomed in. The zoomed out and zoomed in appear to be of a different brightness . I can only assume its because they are a new picture and not a crop of the original. Almost forgot. The white bucket is the 150M mark.
F13 XML2 dedomed over 3 amps at the led.
F13 Cutter 35mm reflector XHP70 3 amps.
DST MTG and XHP at 3.7 amps.
HD2010 MTG-2 2.7 amps.
TN35 and Monster Light.
Zoomed in pictures at the same distance.
HD2010 MTG-2 at 2.7 amps.
Now for some long shots though I would not call either of the DST throwers. Keep in mind the shed is reflective and at a distance of 520 meters.
TN35 and Monster Light. for some reason I have lost the pictures. Sorry.
And finally my favorite light the C83.
The DST MTG-2 lives 99% of its life as a lantern so a comparison was deemed necessary. Both lights have a 1/4 unc thread in the tailcap for this purpose. When the pictures were taken the same cup was used on both lights.
Low.
Medium.
High.
To sum up. The F13 XHP looks useless. In all honesty it does have a shadow in the center of the beam which can be annoying. Would I recommend this reflector, no but at the end of the weekend it was the most used light away from camp. It lights everything up within 75 yards with a wall of a really nice tint light. What did surprise me is how much the light heated up on medium as this is what is was mostly used on.
The DST also has a very slight shadow but this is not noticeable as a rule unless your white walling which I try and not do. If anyone can pick the shadow in these pictures they are doing a better job than I. No comments please.
I have plans to downgrade the 9 amp driver in the Monster light sometime to a 6.6 amp Taskled. Maybe I will just try the XPH70 in this light? Did I mention I love the tint?
And what could be better than my other favorite light that no one owns lighting up the sky after a night taking pictures in the bush. Lets hope its batteries dont run out soon.
I was actually most impressed when used in lantern form. That’s waaay cool how it jus ligjts up your entire campsite. Even low is impressive. What cups are you using?
Have you found any creamish color cups for a more neutral tint?
I did mean to take a picture using a blue cup but forgot. Must of been the full moon. The tint from the plastic cup is ok. They have been in this bush place for over 21 years and it occurred to me one day that they may make a good diffuser. They haven't been drunk from since. These also work well with the TN35. Not what the manufacturer had in mind when they designed it one would assume. It beats having the sound of the generator in the back ground using these as a light source and music is supplied via the car.
Great pics and comparisons MRsDNF. Has that TN35 been modded ?
Very clever use of the lamp base and a ood argument for side switches.
Nice pics MRsDNF. It looks to me like the xph70 has ‘more lumens’ and only produces more throw because of the ‘more lumens’ (if that makes sense).
Great beamshots! How come your daughter (I guess) stays so calm while her head is being evaporated by the XHP70-DST?
The TN35 is stock. There is night shots of it at the longer range in another thread. The XPH70 in the DST is about 18% up on the MTG-2. Lucky my daughter is not in a close up as you'd think she was pretty old.
nice shots!
I once made the mistake to refer to the woman who came towards us (I got a 300km lift from a very nice gentleman in a BMW) as his mother. She appeared to be his wife. Since then I try to be on the safe side ;-)
look at the bright side. You didn’t refer to her as his dad
Just a bump as there must be a few others out there who have shots of this led along with their thoughts on the reflectors used..
I tried an XHP50 in an OP P60 module. The dark spot in the middle wasn’t terrible, but the whole thing was too floody for my taste and it got too hot too fast (even with all the P60 heatsinking tricks). I disassembled it and am working on moving the ’50 to a light with a larger reflector and better heatsinking. Sorry, no beamshots of the P60, but hopefully I’ll get some of the new build.
WOW. Just plain WOW. Love those pics.
For what it is worth in this thread: I made a S8 (my favorite Convoy host now :-) ) with a XHP50 (with a 17DD with zener mod), and the beam is acceptable but not that great. I put an extra spacer between reflector and led to make the led sit deeper below the reflector. Next tweak will be the other way around: bring the led further into the reflector than normal. I think in the end it will be a pretty ok beam, but very floody of course.
White wall @ 5m with flashlight on low, and underexposed to show the brightness drop in the center.
The tree is at 25 meter.
The output was close to 2000 lumen at first but it dropped to about 1000 now, I think I crushed one of the (18350 IMR) batteries, it is bend inwards at the underside :-(
