The power plug is just directly connected to the battery; to charge the battery in the light you'd need a special charger with Li-ion charging circuit; and to use it to charge your phone would requite a special cable with some step-up converter electronics, too. Neither is included in this offer.
Also note that the light has quite some sharp and uncomfortable edges. And in mine 'turbo' is 100% on, while 'high' is about 90% PWM and thus just a tad less bright. Also, if I remember correctly, the button doesn't light up green when the battery is full, only red when empty.
Thanks for clarifying Dr. Jones, so there are issues with most of the bells and whistles on this light.It sounds like a mod is in order for the Warsun, maybe new guppy drive with side switch firmware?
Yes, having that light at home (got it defective for a few bucks, tact switch was loose, easy to repair) sort of feels like an obligation to mod it (custom driver board with dual switch firmware, probably based on lucidrv though), however it has low a priority on my list.
Any estimation on the actual realistic output lumens? They say 1198lm which considering china usual statements could be even be realistic? Or maybe 700-800?
Oh shoot.even though I already owned 2 of these, but at this price I might want to get another 2… as it is a solid light. Throws farther than a C8… and the output is easily bump up by simple resistor mod
Well, this is the comment of Phsinvent take from the review of Chloe (this: Review: Warsun CT9T (1x18650)).
So, anybody here can confirm that there a “new” batch of Warsun flashlight, a sort of 2.0 version, with some improvement?
Well, the price of Banggood is hard to beat…but if you know something, can you please tell us?
It means due to the Chinese New Year, they probably won’t process your order till the 22nd at the earliest. Take your typical China delivery time and add a couple weeks to it so you know when to expect it.
