my Courui D01 project: COMPLETE
21 posts / 0 new
Caleb-v
Caleb-v's picture
ok so i thought i would start this thread so i can show how i did this mod and the challenges i am facing. i know a few others have done this torch and posted about it. But from the results I’m already seeing i think this torch needs more attention. this is my first mod that I’m going to document and post so enjoy Smile
list of parts
*Courui D01
*custom heat sink
*maxtoch 31.5mm xlm mcpcb
*acrylic AR lens
*22mm FET driver( with forward switch)
*Xml2 u3 1A De-Dome
ok so i am waiting on the driver and the heatsink so i have been playing around with the focus and i must say i have been struggling a lot with this flat bottom reflector. reason being is that i am trying to get the led up as far into the reflector as possible to tighten the hotspot. The biggest challenge is getting the reflector as close to the mcpcb without shorting. so i decided to try mount the led on a stand to get it up off the mcpcb .I failed the first time round but have now succeeded to lift it up a bit. i now have the die of the LED basically just popping into the reflector and the hotspot is very nice and tight and bright. so my preliminary results show that the lux must be above 250,000k. (i have no lux meter) but can judge it off my other thrower SR 52vn which is tested to about 250,000k and the courui is just out throwing it Smile
photos to come
As you can see here I have reflowed the led onto some small slices of copper
Before
After focusing
UPDATE: MOD COMPLETE
so i had to wait a while for my heatsinks of arrive (i made two torches) and when they did they were flawless and they fit like a glove. I piggybacked the drivers which was easy and they now have 5 modes and a very low moon. i am super happy with how they turned out. but I’m not sure if i would chose this light as a thrower project again. I think the flat bottom reflector just makes it to much hard work to get a nice focus. All in all i think I’m getting around 300k plus and i can’t complain with the quality thrower that i have ended up with for less than $70. so here are the photos.Enjoy
this photo i am about to apply arctic aluminium
ignore where i put the switch wires they are in the wrong place in the photo
Edited by: Caleb-v on 03/09/2015 - 03:50
garrybunk
garrybunk's picture
Last seen: 2 weeks 1 day ago
Subscribed! I'll be modding mine soon too!
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
electricjelly
electricjelly's picture
Last seen: 2 days 7 hours ago
I have one of these light on its way to me. I wonder how practical it would be to file down the base of the reflector to make it less thick. I wonder if that would be easier and as effective as putting the LED on a pedestal.
Caleb-v
Caleb-v's picture
I tried filing down a reflector of one before to try get some clearence from the wire pads big I went to far and when I tightened down the reflector it pressed in the base of the reflector and is now slightly concave which is making things even harder for me! Maby you can get away with it but don’t go to far.
FmC
FmC's picture
Last seen: 11 months 4 hours ago
If you use the 32mm Noctigon, you can sit the reflector directly onto the MCPCB if you file the outer edge of the reflector base slightly to clear the LED + – pads.
LinusHofmann
LinusHofmann's picture
Last seen: 2 years 6 months ago
Caving in the base of the reflector is actually raising the emitter further into the reflector relative to it’s focal point so I wouldn’t say it’s working against you. Per se.
But be careful you don’t try to go too far and check your hotspot at long range to make sure you’re still getting a nicely defined hot spot there as well.
A lux meter and checking the max readings at distances above 10meters is really essential for dialing in the perfect focus. I used to try and dial in focus just shining the light indoors and checking the hotspot at close range. But that can lead you towards tuning the focus for best performance at short range and actually result in worse throw overall when measured at long range!
On my Courui (with a not dedomed emitter) the slight caving in of the reflector shelf and trying to sit the reflector down as far as possible by sanding down the stock centering ring I actually pushed the emitter slightly past ideal focus. With the emitter dedomed I expect it to be in better focus again but with the dome on it’s a little bit too far forward and actually sacrifices maximum lux at long range/infinity.
And that’s without raising the emitter on a pedestal or anything like that, so just wanted to point that out.
The quest for perfection can often tempt us to go too far in some cases Smile
Here is a little animation I made showing a simulated flashlight hotspot done by sweeping a square die emitter through a parabolic reflector’s focal point.
Link to Mov Video File – Download and play with Quicktime to scrub through frame by frame
The range of travel is only about 1mm in either direction past the focal point (which is passed through on frame 12-13) so not much travel at all and you can see how it affects both the hostpot shape and the max lux of the hotspot (in the sample graph).
My point is just that, once you’ve hit close to the focal point. i.e having the emitter surface close to flush with the base of the reflector it’s about as good as your going to get.
Usually the focal plane of the reflector is flush with the shelf of the reflector). Going any further forward is not really going to result in any higher throw, even if it may seem that way when looking at the hotspot on a white wall or possibly even when measuring it at closer range. Looking at these sims I can see places where the center of the hotspot may seem like it’s getting a bit brighter/smaller relative to the rest of the hotspot. But looking at the actual brightness samples in the graph you can see that as soon as you’re out of the ideal focus range of the reflector the results are always going to taper off in terms of max throw.
Also it’s important to note that pushing the emitter into the reflector is essentially shortening the reflector overall and that may explain why the falloff in hotspot brightness is more pronounced going forward compared with pulling the emitter out (even though pulling the emitter out of the reflector is effectively cutting off the total light output from the lower angle emitted light fromthe emitter. Because of the shelf rim getting in the way – that light incidentally is what makes up most of the corona around the hotspot and doesn’t contribute as much to the defined hotspot)
For me at least it’s quite interesting to see, and play around with this stuff.
Oh and just to be clear these are simulated with vfx grade software raytracers and not to be taken as anything scientifically accurate. For example I don’t believe diffraction is taken into account and of course it’s assuming a perfectly even emission angle and perfectly efficient reflector.
But that said they’re certainly proving to be a good visual guide to understanding how reflectors and emitters interact. I always wondered just what a perfectly focused XML in a parabolic reflector should actually look like and having that as a reference to dial in focus is really useful.
I’m working on a whole series of these type of simulations and I’ll post up a thread at some point when I have some more done. Hopefully other people will find them useful. Smile
Nicolaas
Last seen: 1 year 12 months ago
Quote:
*Courui D01 *custom heat sink *maxtoch 31.5mm xlm mcpcb *acrylic AR lens *22mm FET driver( with forward switch) *Xml2 u3 1A De-Dome
That is my shopping list, how did you know that? Wink
Only (big?) difference is that I have installed the big copper pill I bought on this nice forum.
Waiting for some stuff to come in, I will post pictures and lux readings after that.
Greetz
Nico
Caleb-v
Caleb-v's picture
Greetz
Nico
cool. yeah i am waiting for that copper pill to turn up from NikolaS can’t wait. ps i am planing on piggybacking that driver. and that AR lens is so nice. When i get around to it i will post links to all those parts on the OP
electricjelly
that software looks like a very useful tool. I wonder if it could be used to design the ultimate reflector shapes that would have the perfect focus without any modding needed by the enduser.
LinusHofmann
A perfect shape for projecting a flashlight beam really is a paraboloid, and that’s already used in 99% of all flashlight reflectors. With a perfect parabolic reflector and a true point source of light placed exactly at the focal point of that reflector, it will project a perfectly parallel beam of light. Basically like a laser.
That said you’d have to disregard real world limitation such as leds not being anywhere close to a point source (picking a smaller emitter in relation to the reflector size helps here) and things like inevitable surface undulations of the reflector oh and diffraction properties of light also play a role.
It’s these real life issues of relatively large area sources i.e leds (not a point source), diffraction and surface imperfections and a whole bunch of other little things that cause the parabolic reflector to not do what it is supposed to do.
To get the most out of a flashlight like this though, and that’s what I’m actually interested in. It’s really just a matter of manufacturing/picking a paraboloid reflector of the right size and proportions then slapping the emitter right on the focus. It’s usually that last part that seems to stump a lot of budget chinese manufacturers. Usually it’s just laziness, or assembly shortcuts that cause problems.
The Courui is a great example. The reflector shape is absolutely fine but the stock centering ring is far too tall messing up the focus and not allowing the reflector to work to it’s best potential. All simply because it’s easier for them to clear the soldering blobs that way.
Also on some other cheap lights (I remember the HD2010 had this problem) the machining of the reflector and the resulting focal plane of the reflector is actually correct in relation to the top of the shelf, but the tolerances allowed for the the thickness of the shelf are too loose and that can sometimes require a lifted emitter to get it into proper focus.
I just wanted to point out that there can be such a thing as going too far in terms of wanting to lift the emitter or squishing the wiring down to crazy levels.
I did the same and doing these simulations I am now realizing I actually pushed the emitter too far into the reflector and reduced my maximum throw as a result.
There is a definite sweet spot, the same applies for getting the emitter nicely centered. That can also have a big effect on the resulting hotspot.
electricjelly
Are you talking about the triple / quad / single xp32 noctigon? Have you used that one sucessfully? If so that’s great news. Looks like it adds the most thermal mass.
FmC
FmC's picture
Yep.
G0OSE
G0OSE's picture
Last seen: 1 day 6 hours ago
Hmm interesting, I’ll have to do mine, been sitting on the side for some months now. I made a copper heatsink – I also have the same led as yours, just needs de doming.
Caleb-v
Caleb-v's picture
bump
garrybunk
garrybunk's picture
So how many amps you pulling from the cells and which cells are you using?  I'm only managing 3.05A from (3) fully charged LG 4.35v cells.
-Garry
Tom E
Tom E's picture
Last seen: 2 days 3 hours ago
Garry - I started on CORUI D01 modding. I see two major issues with the D01 that must be addressed for high amps:
  • tailcap - bypass springs of course, eliminate the PCB tracing, and maybe most important, the contact from the PCB to the body is horrible -- I only see the cheap screws doing the elctrical contact. The body surface around the screw holes is anodized. I drilled holes thru the PCB, so use one 22 AWG wire from the spring tip to the ring around the screw holes. This eliminated the PCB traces completely - don't just replace the stock wire jumper with a thicker one. I dremeld off the anodizing around the threaded holes in the body, then added solder on the PCB side, so I got solder to bare aluminum contact, not just the screws.. Also 2 of the 3 stock screws were stripped, so I replaced them with longer ones -- now it's all nice and tight.
  • poor contact of driver ground ring to the body. Maybe the best method is to screw the driver into the body where the driver outer tabs are located. Others, like Dale, have done this. Use a flat head screw that sits in deep into the hole you drill thru the driver to keep them low profile to avoid damage/contact with the batteries. I'm using brass screws myself - good conductance.
 On the LED side, I used the big MaxToch MCPCB, though it's not big enough for clearance. I flipped the pill top piece, and secured it down tight with the camera lens adapter ring someone else found that works/fits perfect. Right now I'm using 22 AWG wires, lapping onto the MCPCB from the outside, not the wire cutout, but still used kapton tape. Better fix would be thin copper extensions, then I can use 20 or 18 AWG wires.
nofearek9
nofearek9's picture
Tom E wrote:
  • tailcap – bypass springs of course, eliminate the PCB tracing, and maybe most important, the contact from the PCB to the body is horrible — I only see the cheap screws doing the elctrical contact. The body surface around the screw holes is anodized. I drilled holes thru the PCB, so use one 22 AWG wire from the spring tip to the ring around the screw holes. This eliminated the PCB traces completely – don’t just replace the stock wire jumper with a thicker one. I dremeld off the anodizing around the threaded holes in the body, then added solder on the PCB side, so I got solder to bare aluminum contact, not just the screws.. Also 2 of the 3 stock screws were stripped, so I replaced them with longer ones — now it’s all nice and tight.
do you have any pics?
if i understund correct your solution this is what i have done in mine :
Tom E
Tom E's picture
Oh boy, sorry it's been so long - didn't see this til now. You basically got it - I'm trying to recall, looks like I didn't have pics, but what I did was add wires (silicone covered, maybe 22 AWG), between the springs, like you did, but also connect to the screw thru-holes, since that is where the contact to the body is made. I recall it was a little tricky to not interfere with the screws, but what I did would totally eliminate the PCB traces. Think of where/how the electricity flows - springs to screws, so that's what I wired.
Update: Found the pics, just never uploaded them. This is how the MCPCB came out:
Not sure bout this one, but think these are the screws I used in place of the stock ones:
Shows the holes drilled thru the PCB, and snaking first wire:
Spring side after soldered in :
Middle wire may not be needed, but added it anyway:
End cap side soldered up:
Think this was dremeled to expose some bare aluminum:
Showing drilled holes and resistor mods:
nofearek9
nofearek9's picture
thanks for the pics.
tru3s1lv3r
tru3s1lv3r's picture
Last seen: 10 months 3 weeks ago
This light has been on my list to get and mod. I think now I’m gonna bump it up and get me one here soon to begin working on. I really like these lights in the gray color. Something different from all my other plain black lights. Quick question though, do you happen to know the diameter of the hole in bottom of the reflector?
Aspiring Fhashlightaholic!
nofearek9
nofearek9's picture
http://budgetlightforum.com/node/26701
LinusHofmann wrote:
The dimensions of the reflector are 70.5mm x 47mm and the hole for the led centering ring is 8.5mm
