I’m not sure about tips on programming in general, but I’ve collected and published several firmwares in one place for convenience (including source when possible). The link is in my signature.
I’ve been trying to collect as many as I can there, but I’m pretty sure I’ve missed some, and a few are still on my todo list.
I just added several more firmwares too, since I had a few on my todo list. And I’m pondering ways to tag the firmwares with relevant hardware requirements, to help people navigate the collection. Like, this one requires an e-switch, that one requires an off-time capacitor, etc.
I had another go at the 17DD single-sided V024 with zener mod, and succeeded this time :-) I used a MCU from a AK-47-A driver, so it is 5%-25%-100%, with on-time memory, not the greatest UI but it is what I had. I used it for a Convoy S8 mod with a XHP50. In the end I think I crushed one of the 18350 batteries resulting in halving the output :-( , but it was close to 2000 lumen at first. I ordered new batteries to see if that was what happened.
board soldered onto the pill.
short brass pillar for batt+, space was tight in the battery tube with 2x18350's.
there you go:
I posted two beamshots in OL's XHP50/70 beamshot thread, but I still have to do tweaks to the focussing, it can become better than that.
Thanks for updating us djozz. It seemed safe to assume that you wouldn’t have any additional problems after those last learning experiences. I’m glad this one went together without issue.
I must admit… I love the gaudy, saturated look the gold plating takes on in your photos.
Odd about crushing the cell. I’ve never squished one that badly, as far as I know. I’ve only dented the end about 0.5mm or probably a little more.
I’m way behind on that thread. (133 posts behind…)
Yeah i found it on google also when i searched on it, but you said “still the best candidate” implying that this was common knowledge that it was, thats how i read it anyway.
When i compare the fig.8 “Drain-source on-state resistance” in the data sheet i think the PSMN0R9-30YLD looks much better.
In a Zener modded board the gate voltage will never fall below 4V so it should be fine. It’s possible that one with better fig.8 numbers might be better for single cell DD but not enough builds with other options to know if it’s worth it to spend $5 a piece for them.
I think that figure 10 is the most telling when comparing those two FETs. By my reading of figure 10 PSMN3R0-30YLD is clearly superior to PSMN2R4-30YLD. (When scrutinizing the datasheet this difference is first noticeable in figure 7, but it’s not clear why… figure 10 shows why.)Both MOSFETs are suitable for use with this driver. Since PSMN3R0-30YLD is less expensive and appears to be the better of the two I’ll continue to recommend it.
I think that DBCstm has decided to go with SiR800DP for future builds, although I know he’s got a few other FETs on hand at the moment such as the very expensive Toshiba units. I don’t think I’ve seen a side-by-side, but it’s always seemed pretty clear that the SiR800DP would firmly beat the PSMN3R0-30YLD. [compare “On-Resistance vs. Drain Current and Gate Voltage” in the SiR800DP datasheet with Fig10 in the NXP datasheets] SiR800DP also costs over double vs PSMN3R0-30YLD. I doubt that most folks will gain a lot by spending the extra.
We use Figure 8 primarily to see where the ‘knee’ in gate voltage happens. We can’t really glean much information beyond that from Fig 8, don’t read too much into it.
Use Figure 8 as an “at a glance” to see whether you should even consider a MOSFET. Once you’ve confirmed that the knee is in the appropriate place focus on the other graphs to get a better idea of performance between good FETs.
Well, I feel my FET question is sufficiently resolved. What about the diodes? The ones I have work fine, but when I reorder I would prefer to get ones with “the line” to show polarity instead of “41” written on top.
What am I looking for in the spec lists to determine if it’s what I want?
The 2R4 and 3R0 are really pretty dang close. I wouldn't pay extra for the 2R4, but it was available in large quantities when I placed my last order, the 3R0 was not. I've used the 1R0, 2R4, 3R0, and 4R0. Between the 2R4, 3R0, and 4R0 it is hard for me to differentiate between them. The 1R0 may be measurably better with fresh cells, but it is hard to tell. It seems like how hard I'm pushing the battery against the spring seems to make more difference at the top end than the FET used. I haven't tried to measure yet down in the 3.6V-4V range, just wide open with fresh cells.
The one that really stands out as a great performer is the SIR800DP. I think that I would take that over the 0R9 or 1R0 for single cell use because entire curve is shifted to lower voltage, which is what you need when your batteries are getting lower. All of them work awesome at 4V+.
I'm wondering if you would see a greater resistance decrease from simply removing the polarity protection diode than you will from going from a $0.65 to $2 FET. Has anyone measured the gate voltage under load with and without the diode in place?
Thanks for chiming in RMM. I think you hit the nail on the head with this bit:
I haven’t measured the gate voltage. Or if I did I was working on something else and didn’t keep track.
I would not think that you would net more than 0.2v at the gate by removing the polarity protection diode… which should net you an improvement of less than 1mOhm under load with the PSMN3R0-30YLD… not a big gain, but that might put it on par with the PSMN0R9-30YLD. I do not think that removing the diode would put PSMN3R0-30YLD on par with SiR800DP, which is currently cheaper than PSMN0R9-30YLD anyway.
Removing the diode might get PSMN0R9-30YLD on par with SiR800DP on fresh cells, but why would anyone bother? SiR800DP still seems to win in general.
