Great mod, i will order the part to see if i like it better than the stock reflector, do you think the TIR would fit an XP-L?
Can you guys help me out though, i totally failed in opening this light
Am i supposed to screw out the driver to get access to the pill or what?
The driver looks glued in, or is the head able to screw open in to parts?
I canāt see any seam that would indicate that.
The head unscrews from the battery tube and also unscrews in half for access to the emitter. The driver is a simple press-in IIRC. The optic fits an XM-L so an XP-L should fit fine too. You'll probably want to use the XP centering ring instead though.
Did you buy yours from the ebay seller or fasttech? mine is from ebay.
I think mine is glued together it really donāt want to open i canāt even pry the driver out, it already have scrapes all over because it just donāt want to budge.
I guess i will have test some intense heat on to see if it will loosen up the thread lock gunk, i hadnāt planned to use the driver or led anyway.
Nice that the optic will fit the XP-L (sorry i missed that you used a XM-L of course it will fit then it was the fasttech description that threw me of) & good point about getting the correct XP centering ring.
I donāt have any extra o rings, where did you get yours that was slightly thicker O-Ring & a better fit.
Did you use a copper DTP mcpcb on this, i wonder if the optic+thicker o-ring is including the thicker mcpcb like a noctigon or sinkpad?
Applying intense heat worked but i melted the reflector+led because i got it to hot to bad, now i need that TIR & fasttech arenāt shipping because Chinese new year.
I managed to poked out the driver from led side, it probably was just pressfitted in but i just couldnāt get it moving from the battery side.
EDIT
I just realized that it was probably the wires from the star that held it in place, they where so short it would have been impossible to get it out of the head anyway.
I havenāt even any 14500 batteries anyway so i need to get those first before i can even do anything fun with this but this is a really nice host now that get to look at all the part separately.
One potential problem i see could be there extremely tiny space for the driverā¦ā¦ i am not sure it is possible to fit a nice FET driver in there, i will have to make some closer measurement for that though.
I canāt show the reflector and led melted together, because i was disappointed that i did let them get too hot (and they smelled really bad, i did get a slight headache for a couple of hours by it), so i just flushed them as soon as they where cool enough to remove to get them out of my sight i used a hot air gun, unfortunately for a bit to long. I stopped as soon as the temp was 150 degrees Celsius on the IR temp meter, that was obviously more than enough so next time i will test lower.
Anyway it is good to know it is this easy to get some thread locks to crumble i have some Hugsbyās i may want open soon
I will try to get some pictures taken later in the evening.
EDIT sorry, i canāt upload any pictures for a while, my phoneās Internet/MMS function seems to be down at the moment.
@deputydave: I don't have a light with the stock emitter on hand at this time to check. I assume it would be similar, but much dimmer.
@cajampa: That's interesting that yours is glued. Mine is from FastTech, and I don't think it was glued, but I have the two eBay lights that should be here soon. I'm curious if those will be glued. I'm not sure what the hold-up is; I ordered two lights at the same time from different sellers. The first was shipped without tracking, and I received it a week ago. The second (these two lights) was processed through the Chicago ISC on Feb. 08, then are listed as having arrived at the Chicago USPS facility on Feb. 11. There have been no further updates. I'm hoping they will show up soon.
Thank you sir. In regards to the Ebay version and shipping I experienced the same delay through Chicago, in fact it went from Chicago to Detroit before heading finally to Florida which I thought was odd. Tracking indicates that theyāll be delivered today so that would be a total of 18 days.
@keltex78,
Could you answer these? thanks
āI donāt have any extra thick o rings, where did you get yours that was slightly thicker O-Ring & a better fit.
Did you use a copper DTP mcpcb on this, i wonder if the optic+thicker o-ring is including the thicker mcpcb like a noctigon or sinkpad with your XM-L2?ā
The O-ring I used was a spare from my kit... I have a lot of different sized O-Rings that I've purchased and that have been removed from other lights. I just looked through and found one that worked. It's not an unusually thick one, it's just a standard GITD O-Ring like you would use on a P60 host or anything else. It's just a bit thicker than the thin ring that was already on this host. I trimmed it down to fit myself.
I did not use a DTP copper board, just the thin aluminum board that my emitter came with. If you have a thicker PCB, that might make up the difference. Although, I did flatten and polish the shelf the PCB rests on for improved thermal transfer, and that would have lowered my emitter slightly, yours may not need the thicker O-ring.
Okay, I did in fact receive these lights in the mail today. Put an Eneloop AA in each to test them and they seem to work fine. The star isnāt really seated inside the head, the wires just kinda hold it in and the reflector holds it down in place. I compared it next to the Acebeam L10 (both using an Eneloop AA) and they seem fairly comparable. I havenāt tried a 14500 yet. I lubed all the threads. Probably well worth the $2.99 each. Time will tell for sure of course but they seem to be a pretty decent little light.
I also received a pair of these lights today from Ebay vendor linked above.
The threads on both were so sloppy loose that they caused a ridiculous amount of misfires and mode skips. I wrapped a single layer of metalized/foil tape around the threads of each and now they both function as they should.
With this simple repair, they are now great for the price.
Trying it now with one of the purple GTL (eBay) 14500 batteries. It is brighter but doesāt seem to be head-n-shoulders brighter. Been on for maybe 5 minutes now and itās fairly warm but I can still hold it without issue.
