Ah, thank you. I’ll need to look into that.
The pair I ordered from the eBay vendor arrived yesterday as well...
Like cajampa mentioned above, the head on both of these appears to be glued to some extent. I'll be working on getting those broken apart for modding soon. I have a small strap wrench that should help... a crescent wrench or vice might help with retaing the hex side of the head without damaging if you tape the jaws...
I think I might have to buy one or two. I’ve been thinking about replacing the Fenix LD01 on my key ring because I dislike AAA cells.
If you change the bottom supposedly steel spring to a better one with lower resistance like a carobronze or even better beryllium copper spring, it will get brighter.
And the strongest 14500 battery i know of is the Windyfire IMR14500 10A, that would also improve output.
Checkout HKJ ’s test
Comparing side-by-side, it's apparent that the lights from the eBay seller are not exactly the same. The light from the ebay seller is slightly longer, by about 1/8" (3mm). The anodization is a bit different, but they otherwise appear to be the same.
Thats interesting,
Is the front part that holds the lens the same shape? i ask because in your picture of your modded fasttech one, i suspected that my ebay one was slightly different.
Thanks for the suggestions. The GTL 1600mAh pretty much sucks. I’m getting about 10-12 minutes out of a fully charged battery in these lights on high. The only other 14500’s I have on hand at the moment are the TF flame 900mAh but haven’t tried them yet in this light. In the SK68 the TF got 1 hour 20 minutes and stayed bright the whole time till it shut off. In the same SK68 the GTL lasted only 50 minutes and quickly got dim.
I’ll have to toss a TF in and see what kind of run times I get on high and low.
Thats interesting, Is the front part that holds the lens the same shape? i ask because in your picture of your modded fasttech one, i suspected that my ebay one was slightly different.
I don't have the means to post a comparison photo at this time, but head-on, they are both the same. I think the difference you may be seeing is just perception due to the TIR optic.
Ok good to know, i agree that it is probably the TIR & also that slight fish eye effect you can get in closeups in photos.
I wonder if you can figure out where we got the 3mm extra, maybe we got a thicker shelf but i wouldn’t bet on it is probably something useless like a longer tube.
But a deeper driver area would be nice also.
Yes, most of the difference is in the body tube. There is only a marginal difference in the size of the heads.
Anybody else experience sloppy threads in these super lights...or was I the Lone Ranger here?
I’m curious about this also as I have one coming from ebay and one from Fasttech. If anyone can comment on any noted quality differences between the two sources I’d appreciate it. Mine should be here soon so I’ll do the same once they are received.
Thanks,
John.
Mine is also very lose but i had no problem with mode changes though.
But i used mine just to check if it worked at all, as a stock light, i wouldn’t want to use it on AA anyway, very dim & a blue harsh led
Maybe it gets nicer stock with a 14500 in it, i bought i as a host from the start, for a nice XP-L V6 in a tint i like + wight’s FET+1x7135 driver
I hope i can fit it in there it is a little cramped for space, but i just realized i can use a 17mm driver in this nice, that makes this much more possible.
Oh well, it was an EZ fix. Mode twisting functions and fires like a high dolllar torch now.
Always good to know how to tune up the threads, when i start to use it if i need to
You used just a little aluminum foil tape right, like this ?
That's right. I started with teflon but it wasn't enough. The foil does wonders for sloppy threads.
Here is some pics on the disassembled Super Light.
Top of light where the o ring + glass lens holds it in by the reflector that i accidentally melted
Driver compartment
It is 15,47mm to the bottom of the driver area & 10,82mm to the ledge that the driver sits on & it is 4,65mm deep.
The driver area is 14,97mm wide & the ledge that the driver sits on is max ~17mm.
The shelf that the mcpcb lays on is 17,10mm wide, it is anodized so if sanded down to bare aluminum it would provide better heatsinking
Boost driver board is 16,90mm wide
Battery tube with spring
Size comparison with my Jexree Mini
And a Pen
Nice…thanks for the pics
I see that this one still has the divot on the emitter shelf. I used a file, sandpaper, and rubbing compound to flatten that out...
Yeah, it is so much easier to work on the shelf when it is inverted like in this light so you don’t have to try and do all those things, down it to the head like in most lights.
But i think we get a little worse heatsinking when the head is in 2 pieces like this, maybe if we wrap the threads with some copper tape like how they wrap the P60 inserts to improve heatsinking.
