The reason for the lack of P31 numbers is that it was bought to give to someone as a replacement for a failed light - it was only in my hands for about 2 days. It is now in regular use by a cop. Our local constabulary only issue alkaline AAs so i looked for something with good performance on those.
AFAIK the P32 is just a P31 with modes and I like it a lot. It certainly seems to be just as well made and is certainly exceptional quality for the price which is less than I paid for the P31 which was $14.31. The P32 was $13.something. Unless you are hooked on single-mode lights I'd definitely say get the P32 instead of the P31.
Yes, the lightbox measures total output, the throw number is got by clamping the light to my desk, the base of which is exactly 1 metre from the ground, so that the emitter is level with the base of the desk. Then I move a lightmeter around in the hotspot till I get the highest value which is sometimes not in the bit of the hotspot that seemed brightest to me. In other words, the throw value is the absolute highest value I can get out of the light. This tends to favour lights with small hotspots - a light can have quite low lumen output but still throw farther if just about all the light is put into a very narrow beam - think the useless light you get in Doom 3.
It would be more accurate to measure the value at 5 metres and calculate it back to one metre using the inverse square law but I have no light-tight part of the house that has a clear path of 5 metres. Maybe the basement after dark but it is cold, damp and doesn't have enough height to stand up in. Also the hatch hole is very small and I have to empty out a cupboard to get in there in the first place.
[/quote]
Thanks Don
KD has the P32. Kost 13.57$ They state its a 90 lumens light. DX says 160 lumens. Both are Q3.
They are probably unreliable both of them. I trust your measurement. midieval10 says that box says
The AA-S1 with a 14500 is clearly brighter than the P32 with NiMH - the hotspot is several times the size though the spill is of similar brightness - the beam from the AA-S1 is wider. Here's a beamshot about 60cm from the ceiling. Will try outdoors beamshots of the two once it gets dark.
As medieval told, quality not so good, and now less bright. Dont buy... is a new batch, was sold out on June-July. New batch from latter July - August. Bad
On mine which I got early august, the quality of the build is quite decent. Coating is very hard (seems like ha-iii). The only "problem" on mine is I"m not sure whether the kinda poorly defined hotspot is due to the emitter board being slightly offset (and way too much thermal glue). I'm getting a smooth reflector to see if I can improve. it.
The coating on mine is pretty soft - you can see scratches on it where the wire clip has moved against the knurling. A Hugsby P32 which claims type 3 anodising can scratch it.
I used pliers on mine and paint only came off where I took off/reshaped the base metal. Maybe it's just really tough ha-ii.
The wonders of chinese quality control.
Interesting aside: some tools/knives I got from china have a pretty tough black finish on them (not just cheap paint). The same finish is somewhat expensive (~$10) on similar "brand name" tools. It costs <$1 on the chinese ones.
I got the red black cat 5000k from kd today. It's very good, and surprisingly 5000k (not warm like the pic previously featured here, I suspect that's the "yellow" warm version). A little less bright than the AA-S1 with nihm, but not night and day.
Buy it.
BTW, the AA-S1 I have is not nearly as bad as midieval's, and I only got it a couple week before this. Mine is quite bright on 14500 as well (~200lum I'd guess). His looks awefully white in tint (more so than the crees), and only my nice warm cree drop-in is warmer than my AA-S1 osram. Oh well, chinese lights.
I have noted that the older versions of Black Cat were coming with a LED with 5 divisions (4 lines). Now they are coming with 2 divisions (1 line). So I beleive that the one with 5 divisions is Golden Dragon Plus. The one with 2 division is simply Golden Dragon.
I imagine that with the AA-S1 happens the same, previous versions were with GoldenDragon PLUS and the last ones with simply Golden Dragon.
Do you have a convex lens? can you put one in front of the AA-S1, light it up and see how many divisions has yours?
Also Don can do the same in his S1, also Medieval, to compare
Look the drawing showing the LED die. First versions of Black Cat were coming with a LED which it´s die was like it, 4 lines, 5 divisions. Now the Black Cat is coming with same LED but with 1 line, so 2 divisions and is less bright than older ones.
I beleive that the one with 5 divisions is GDP and the one with 2 divisions is GD (not Plus)
I whish to know if older AA-S1 were coming with 5 divisions LED and newer are coming with 2 divisions LED
The digikey link above will go to photos of the emitter. I don't know what xrayboy is drawing, but it's not a dragon plus according to digikey (one of the premier US parts suppliers).
