Thanks guys i don’t know why i so enjoy these kind of discussions, i have really tried to get a grips on how it all functions but when they keep using different scales to describe the same feature & i try to recalculate it to compare the graphs in my mind i always fail no matter how hard i try.
Maybe thats why, it is almost a little mysterious to me someday maybe someday.
The biggest thing i got from this was that i had almost totally missed that the SIR800DP was seemingly now suddenly (to me ;)) the strongest performer.
And the removal of polarity protection diode “mod” if one could call it that, so SIR800DP+no diode :bigsmile: = max possible performance :bigsmile: + some extra pressure on the spring if possible = even more
Just to double check so i understands things right, because i just realized that i totally missed to buy any diodes anyway. the diodes is the “D1 – SOD-323 & SOD-723, assorted” from the OP (i mistakenly thought that was for the with Zener functionality only) can any one give me a good pointer on what to buy.
I got wight’s
It must be able to withstand the full battery voltage in reverse.
Low Vf at around 5mA.
And i saw pilotdog68’s point about easy markings, so i don’t have to measure every time i want to make sure.
I can find SOD-323 at 5v but i haven’t found one with 5mA yet just way above, that makes me think i am not even on the right kind of diode yet.
So what are you who are already building these using?
Is this the correct type?
I have tried to find one but i can’t find one that is in the range of the whole 2,5v-4,3v for single battery use & with a Low Vf at around 5mA
And if try to include a marking also i get even worse hits………
No, that is the wrong type. I did not think to mention it when pilotdog68, but it must be a Schottky diode.
There are carts on page 2 of this thread. Those include an appropriate diode. While there are certainly better options on the market, the ones in those carts are the ones I’ve tested.
I’m sure this is answered somewhere but I’m unable to find it atm.
Is the input of the voltage divider connected to Vin or to the output of D1?
Output of D1 would mean voltage monitoring with the Zener mod is not usable because the max input of the divider is the Zener voltage?
Reading the datasheet, vF is about double the vF of the NSR0320. On the other hand its half the price.
Looks appropriate to me.
Sorry for highjacking this thread:
I’m currently fighting one(now 3 of these drivers) to get them running at >4V input.
Maybe some of you can take a look? A17DD Driver does not switch modes
It matches the Vf of a diode that wight recommended but at 1/3 the cost. It sounds high, but it’s in the lower Vf range of the diodes mouser has for sale.
With 3.67V on the driver input (while running) I measured 3.51V at the FET gate full on. At 2.99V I measured 2.833V. This is with the "ultra low vF" diode. It was pretty consistent at around 0.16V difference from input voltage to gate voltage. I need to swap in one of the cheap S4 diodes from the 105Cs and see what kind of drop I get from that.
Hi, these days I tried to study about A17DD-SO8. I find single side design a great feauture. I have some questions though.
How much is cost of this board, compared with classic 17mm fet blf fet driver? Except it’s single side design, does this board have advantages compared with blf fet?
The cost is pretty much equivalent. It is easier to build and fits in more lights. The performance is equivalent.
Finges: there was already a specific zener mod FET driver. You could also easily modify the earlier revisions as well (but not the v1.0 versions without some modification).
I don’t do Windows. I was looking at cheap Windows laptops to program drivers and wondering what are the minimum requirements to program these and other boards. If you guys could suggest what is needed that would be a big help, thanks.
It wouldn’t take much at all, a $50 (used) netbook could probably manage it. They are very simple programs. Most of the tutorials are for windows, but a few people here do it in linux as well. That could be a cheaper option.
I don’t do Windows either. You can flash stuff from Linux if you like, and I have instructions available for setting it up in Ubuntu. You should be able to run it on pretty much any computer with USB, though on older ones you may need a lightweight version like Xubuntu.
