These dropin shells will fit all of those hosts and many many more. They are pretty universal.
If you plan on running a dropin at full power, 6-9 or more amps These are amazing. At conservative power levels there’s not much out there that will beat solid copper.
There is very little thermal sag and the led stays cooler longer.
You will still have to add a small piece of foil to the biggest part of the dropin for a snug fit.
I ran a nichia 219b triple in my hand at 4.5 amps for over 5 minutes and the shell was getting warm but not by any means hot.
In my opinion these are the cats ass for triples. At least high powered triples. They also fit everything needed perfectly.
(edit) I was wondering the same things when I first ordered the others from mattaus. Once they arrived I knew I needed to have more.
Hi everyone, I’ve been crazy busy with work, sickness and a very late spring (still isn’t here)
I’ve had these almost two weeks and if there’s still interested people I have 40 available.
If you’d like completed triples I’ll be updating my p60 build thread in the coming weeks. I’ve got a couple of projects I’m working on right now so the dropin factory will remain closed for a bit longer.
I’ll like to order 4 of your copper P60 shells. Is the price still the same as the previous batch at $40 for the first one and $30 each after the first?
You can PM him here and he should get an email notification about having a new private message on blf. However, I did that about a month ago and never heard from him. Good luck.
I have one we could use as a template, and actually have the original drawing files from Mattaus and his blessing to make more. Problem is I don’t know who might make them. Hoop once said he would make some, but I don’t think he’s around anymore. Anyone know who could make these?
