Any Windows laptop from the past ten years will do everything you need to program these drivers.
I don’t do Windows either. You can flash stuff from Linux if you like, and I have instructions available for setting it up in Ubuntu. You should be able to run it on pretty much any computer with USB, though on older ones you may need a lightweight version like Xubuntu.
I wonder if it would work in WINE in Linux?
AVRStudio might work in WINE, but why would you want to?
true
Because you don’t need it
http://www.ladyada.net/learn/avr/setup-unix.html
would probably work on a Raspberry Pi…just take a while to compile
My buddy compiled some software for his ham radio for a relay…said it took over 6 hours!!!
Thank God for screen
P.S. I like using checkinstall instead of make install…it creates a binary for later installation
I Recently was unable to get a v44 with Zener to work. RMM saved my day with the suggestion to place the input cap directly on the Zener pads.
Wight. If you find the time it would be great to have another layout with additional 0805 pads by the Zener. Right where the v44 silkscreen is now?
Checkinstall is nice if you need to build unpackaged stuff from upstream… but in this case, it’s much easier to just install the existing packages:
sudo apt-get install gcc-avr avr-libc binutils-avr avrdude avrdude-doc
Those are all the necessary tools.
Then, to build and flash most attiny13a-based firmware from inside my repo, it’s just “cd person/project ; …/…/bin/build.sh foo ; …/…/bin/flash.sh foo.hex”.
And, of course, use whatever you like to edit the sources and manage files.
Thanks guys. I don’t know Linux but I used to know windows. Probably go with the evil I know.
Oh, do you normally use a Mac? If so, this might help:
http://www.ladyada.net/learn/avr/setup-mac.html
Or maybe this:
http://www.meoworkshop.org/how-to-avr-with-osx/
Afterward, you should be able to use everything in my firmware repo, including the build and flash scripts, with no need to muck with Windows or AVRStudio. This stuff is all designed to run on unix systems, so it’s basically native on Linux and OSX but it’s a little awkward on Windows.
Can it be used 1mf 16v instead of 25v cause i have like zounds lying arround in the office?
Yes
I have a problem with the Offtime memory. The driver change the mode with first clic even though I cut off the power for a few minutes.
I changed already OTC capacitor, just to be sure it is right value.
Other features seem to be working correctly.
I am using layoyt v0.24 and flashed with star offtime v1.2.
seepeli, can you take a pic and show us your driver? Makes it a bit easier to figure out what’s going on…
I’ll take a picture when I get home.
Sounds more like a bad/dead capacitor, Do you have a DMM with capacitance option , measure the capacitance individually.
If not, remove both capacitors, put fresh ones, preferably from a different batch.
has anyone been able to use any version of wight’s boards with a zener mod as was intended with the design layout? or has everyone had to stack c1 and the zener diode together? does only RMM/MTN’s board work with a zener layout as intended?
I measured both the capacitors capacitances and they were OK. I installed capacitors back and I got OFFTIME memory to work. I may have originally installed the capacitors the wrong way?
In any case, the driver works, so thanks to all!
Those caps aren’t polarized so something else was iffy.
I meant that the capacitors may have been on the wrong places, not in the wrong direction.
Sorry for the bad English
Built my first one of these today. Had some issues at first I couldn’t get it to work checked every thing, diode direction, shorts ect… but could find any thing then I thought it might have been the firmware I flashed it with so tried a different one just to find out it couldn’t flash to the ATTiny13a I was using, swapped it and and hey presto it works.
Its now in a C8 with 25R powering two modes just need to get a dedomed XM-L on copper to finish it off J)
