Uniquefire UF-1405 - A worthy zoomy?
The size and style of UF-T 20 or UF 1407 but with a 26650 tube will be a dream. Too bad that something like that is not available.
Regards
Removing the battery tube from the head requires removal of the pill on 1405’s. Not exactly a quick change deal. If I do it, I could check into extension tubes perhaps.
the JAX z1 & send nits B-650 are good flashlights with 26650
Or perhaps just machine off the flange on the pill so the head stays together and make the whole thing quicker to disassemble. Still seems inelegant compared to keeping the head sealed up and using an extension. (less opportunity to get crud on your LED and inside of the lens)
I’d order two if you did this (as long as you would be willing to ship to Canada of course).
Perhaps we should open a new thread dedicated to the 1504 and gauge more interest?
I’ll do that.
Great thankyou!
KKW, you realize BLF forum members are from all over the world. Shipping from the US to other countries is very expensive. Canada used to not be so bad, not sure now. I can easily see the shipping cost being almost as much as the light itself.
starting from austria its definately over 20 USD into "the world" :(
The biggest one in that photo is the 1405 correct? or is it the 1407… 1406… 1504… now i’m confused. :stuck_out_tongue:
OFFICIAL Group Buy thread for UF-1504 (flashlight and host)
sorry for a question that has probably been already answered, but what is the best driver option for this light with a XM-L2 ? The higher the amps the better
1405: 67mm lens, 2*26650
1406: 50mm lens, 2*18650
1407: 40mm lens, one 18650
1504: 67mm lens, one 26650
And there are more similar model numbers in the Uniquefire website … can’t remember all of them either.
Hope this helps.
Hello!
LD-4B driver and MT-G2 led fits in this flashlight Uniquefire UF-1405? Not high the driver? Should be used MT-G2, or XP-G2 recommended?
Sorry for my bad english. :8)
Thanks!
Yes the LD-4B does fit well in the 1405, and it can run a single MT-G2 or a single XP-G2.
Thank you bibihang! :slight_smile:
You’re welcome. :beer:
can the stock driver(modded with resistors) run a xp-g2 LED? Or what is the best emitter/driver combination for the ultimate throw ?
The stock driver can already run an XP-G2 without any mod, but the current at the LED is not high, which is around 1.6-1.8A only. You can add resistors to the stock driver to bump up the current but do this in your own risk, as there have been a lot of cases that the stock driver failed at high current (including mine). The 1405 stock driver is just a lousy driver to say the least.
For the ultimate throw combination you can use dedomed XP-G2 or XP-E2, but the XP-E2 will give you a laser-like tiny hotspot. To get the maximum throw out of each emitter, the XP-G2 should be driven at 4.2A or a bit higher than that and the XP-E2 should be driven at around 2.4A.
Does it need mentioning that the leds need to be on a copper DTP board?
