Ordered one even though I have no idea what to do with it (I have never had one before). Thanks Hank!
I’m sure you’ll find a use for it once you fire it up for the first time. They’re pretty special emitters.
I’m sure you’re right! I just have a lot of research to do. I don’t know a lot about them and I am trying to find a host that’s not too hard to put together and is on the budget side of things.
I’m thinking of this one if it is still available. It looks like all I would need to do is grind down the 22mm FET driver from Mountain Electronics.
LinusHofmann: tristanxoxo:Ordered one even though I have no idea what to do with it (I have never had one before). Thanks Hank!
Lol, those are my exact plans (except slightly different driver). I guess I’m not very special
You can find more info if you search for “Roche LS01”
DavidEF: LinusHofmann:Here’s hoping Hank has heard rumors of a 90 cri 4000 lumen mt-g3 and is quickly clearing his old stock to make room :bigsmile:
Better than that would be if they did to MT-G2 what they just did with XP-G2/E2. They came out with a “new” XP-E2 Torch emitter that has the same output as a XP-G2, but in a smaller die size. Maybe they could make a single-die MT-G2 equivalent output emitter in XM-L2 die size! I know they already have XHP-50 and XHP-70 but those are quad die.
Since we’re speculating wildly here
I’d love a smaller or rather, a more tightly packed mt-g2 array die. That would be great, it’s all about minimizing those inter-die gaps.
But I think what we like so much about the mt-g2, primarily for me the nice even tint and decent output is mostly down to that multi-die raised array pattern of the emitter. I suspect a single die version the size of an XML would simply be an XML, if you get my drift?
I hope Cree will actually keep developing the MT-XX range and not just shift to quad die emitters to fill that requirement.
An XML that puts out the quantity and quality of light like an MTG is exactly what I’m talking about. I didn’t know the MT-G2 was a multi-die emitter. But, what I’m asking for is more light in a smaller die, like they did by making a “XP-E2 Torch” emitter that acts like a XP-G2 in a smaller size. I don’t really care if they do or don’t continue the MT-XX line itself, as long as the technology is improving. If they want to make a smaller MT-G2 and call it XM-L3, it won’t hurt my feelings.
Don’t bother to buy it… I have one, it’s bad quality , go for Supfire L3 from RMM, much better light and host
Thanks Hank. Ordered a couple 25mm and 16mm's.
Thanks Hank.
Unfortunately, I still have 2 bare emitters with which I have no plans.. So no meaning of buying any more.
Thanks for the great stuff!
Thanks Hank, I’ve ordered 10! Will be passing on the deals for the de domed version!
Thanks again for the great deals Hank. Order sent.
Good deal guys (that's less than I pay for them).
So which host will the 20mm Noctigon MT-G and LD-2D driver (13mm tall/20mm od) fit into for 2 or 3 cell operation… 26650 preferred.
Since it’s such a good price, I wanna buy one…l haven’t really looked into these at all.
Can I go wrong with this one? Thinking about getting it for an aspheric. (Possibly an uf 1405)
CREE MT-G2 Q0 on Noctigon MT-G16 MCPCB
6V Version
Approximated light output:
920-970lumens @ 1100mA 25°C
2116-2232lumens @ 3000mA 25°C
Color temperature: 5000K
Thanks!
6V Version
Color temperature: 5000KThanks!
As long as you’re happy to have a zoomed in hotspot that looks like this…
…then go right ahead
Am I ever! It looks like the future! At least what we pictured it as in the 80’s.
I figure with the 16mm I can play with it and try it in multiple lights.
hehe, it’s a great emitter. IMO best suited to flood type lights but if you like the look of the die projection you can certainly make it work in an aspheric. Other members here have put it in a Jax z1 and similar lights so if you search for that you’ll see what it can do.
Still waiting for my 10 MT-G2s to arrive…sigh… i hate the waiting part
A purely 6V single die version of the XHP would be sweet. I think the quad die might be a consequence of 6V/12V versatility.
I always thought that a single die blue/white led has an inherent forward voltage of around 3v, and to get a higher voltage white led you have to string multiple dies together. e.g the 6v Mt-g2 is not a single die led but an array, xhp is a quad etc.
Maybe they could do something to minimize the gaps between multiple dies though, that would be good.
I’m just waiting and praying for an MT-G3, higher CRI, higher output, denser array pattern etc
Rufusbduck:A purely 6V single die version of the XHP would be sweet. I think the quad die might be a consequence of 6V/12V versatility.
Maybe they could do something to minimize the gaps between multiple dies though, that would be good.I’m just waiting and praying for an MT-G3, higher CRI, higher output, denser array pattern etc
Right ON! And if I might add (praying wise) a 8.4v 26650 size battery too!!
