The Offtime-Cap.c (.hex) firmware blinks out the ADC value of the voltage on the Offtime cap. This helps tweak the short press and medium press values for mode switching in other firmwares.
Maybe the first level is too low to light up the emitter.
And if it won’t change modes, the OTC values are probably way off.
I’m just guessing though.
Oh, wait. You mean offtime-cap.c? You might want to set BLINK_PWM to a higher number, perhaps. If it’s set high enough, it should at least blink once briefly after it turns on, since a zero will still register. But it’s half as bright as the regular blinks, and much shorter, so it might not light up at all if the #define is too low.
For a value of 203, for example, it should blink out “_ , ., _ _”. Or for a value of 0, it should blink out a single “.”.
But, of course, if it gives you a zero, the OTC is either not working or has been off for a long time.
I must have a compile issue. The .hex from your repository runs, but the blinks are too short for my driver. When I change BLINK_PWM and rebuild (Studio 6.2) the PWM pin just goes to 1 volt (?!) with no pwm. The .hex file I made is 132 bytes yours is 688 bytes.
Let me redo this from scratch, I have something wrong here.
EDIT: Working fine now (deleted all and recreated project) - operator error. Thanks ToyKeeper!
Okay, was BLINK_PWM the only thing you needed to change?
To help make it work on more drivers, I set it to 20 and re-published a new build. That way, even the “zero” blink will be at a level of 10, which should show up on almost anything.
Yes, all I changed was BLINK_PWM (to 40, because of my PWM-to-analog driver). 10 is probably fine for the bulk of the drivers. Of course after that success I also changed the Vref to Vcc just to see where the OffTime cap voltage range is. My driver runs on either two or three cells, so Vcc is stable at 5V. With 1.1V vref I was reading 255 on short clicks. With Vcc vref the counts were at 60 to 45 range. I'll need to do some more testing to find good values for medium and short presses.
So now I've been working with Battcheck.c to figure out where that count is. I plan on adding a second low battery step-down mode, one at 9V and one at 6V. Somehow I need to differentiate between three dead cells (9V), and two full cells (8.4V). Sounds like disaster waitin' to strike. :)
I not asking for help (yet) but I'm open to any advice.
THANK YOU for posting and hosting these programs as well as the others in the repository.
hey, im looking for a “step by step” tutorial for programing the Attiny13A useing an arduino,
just like drdanke did here in post #29, but if possible with more details and maybe even a video,
i like the idea of not need to buy the programer and the clips, and i do have the arduino alrady.
Just so happens I have another USBasp on the way. I found the latest firmware and will update one of the units when it gets here. BTW: I’m not used to handling things like this with open chip leads w/o being grounded with a wrist strap. Has anyone had an ESD failure? I think when I’m done flashing the new firmware, I’ll slip it into some 3/4” clear heatshrink tubing and shrink the two ends.
I took the next step and loaded Atmel Studio 6.2 (along with some serious bloatware from Microsoft). So far, all the c files I’ve looked at compiled fine. Finding the optimization settings was a hoot. Looking at the code, quite a bit of it makes sense.
This is all coming together just in time, because the 22mm 16 X 7135 boards arrived from OSH today, and the F13 light is in transit. I’ve got two or three other projects underway as well plus a test bench.
Okay, I made a version of STAR which uses brownout detection instead of an offtime capacitor. It’s just STAR_off_time 1.3 with that one thing changed; otherwise it’s identical.
Not guaranteed to work on every attiny13-based driver, but it works on all the ones I tried. I hear the brownout timing can vary depending on some of the other driver components.
There isn’t really any advantage to it if you already have an OTC installed. It might save a few bytes, I guess, but mostly it’s just to get an offtime-based UI on lights which don’t have (or can’t fit) the capacitor. I use this trick on a couple qlite/nanjg drivers.
I use a USBasp 2.0 programmer and grew tired of the annoying “cannot set sck period” error message every time I used it, so I fixed it (updated the firmware) for $3—and ended up with a backup programmer in the process. I gleaned the following info from a few sites including the programmer’s site. This only works if you’re currently using a USBasp 2.0 programmer.
1. Buy a USBasp 2.0 with 10-wire ribbon from Ebay, Fasttech or wherever.
2. Choose which programmer you’re going to update (the target) and mark it with a permanent marker or something,
3. Document your clip ribbon connections to your existing programmer and remove them.
4. Optional: Make sure your new programmer works. Connect to a clip, clip to an attiny13a, and test the connection. I use “avrdude –p t13 –c usbasp –n” (without the quotes).
5. Jump JP2 on the target USBasp to put it in programming mode.
6. Connect the two USBasps with the 10-wire ribbon. It can only connect one way.
7. Get the new firmware either from the developer (needs to be compiled) or get the hex file here . Lazy arse that I am, I got the hex file.
8. Put the hex file in the correct directory.
9. Plug the non-target USBasp into the USB port
10. The new firmware requires different fuse settings on the target programmer’s processor. I used the command line “avrdude –c usbasp –p atmega8 –u –U hfuse:w:0xc9:m –U lfuse:w:0xef:m” (without the quotes).
11. Flash the hex file to the target USBASP to update the firmware. I used the command line “avrdude –c usbasp –p atmega8 –U flash:w:usbasp.atmega8.2011-05-28.hex” (without the quotes). If you made your own hex file, use it in the command line.
12. Disconnect the 10-wire ribbon and remove the jumper from the target.
13. Connect the clip ribbon to the target and repeat #4 above. The “cannot set sck period” error message is now a thing of the past.
You should now be able to flash error free. Oh, I had both programmers set to 5 volts.
I have only flashed one chip with the new firmware, and it works, but I am leaving the non-target with the old firmware just in case there is some issue down the road.
I think you're the only person who has ever cared to update their firmware. It's never caused any problems for me or anyone else that I'm aware of, so my opinion has always been "if it isn't broken, don't waste time trying to fix it".
That said, I applaud you for figuring out a fix for something that isn't really broken just because it bugs you. It sounds like you'll fit in really well here (we've all been known to do things like this).
TK - I tried this firmware on a single sided Nanjg 101-AK-A1 (from IOS) with 2 added 7135's (2.1A total). This driver really has no space for the OTC cap I could find for it. Mostly it worked great:
quick click detection had excellent timing and works reliably
LVP kicks in at just about exactly 3.0v, but with an issue:
--> It blinks 3 times ok, but immediately goes into moon mode after that, instead of ramping down. I'm using your recommended fuse settings (not sure what those settings mean: -Ulfuse:w:0x79:m -Uhfuse:w:0xed:m). Everything else is untouched, your original code, but set my own mode PWM values, including 5 for moon mode assuming that's the minimum for 7135's.
I carefully reviewed the LVP code and didn't see any differences, and the logic appears correct, using the ALT_PWM port value. Looks like it should cut output in half each time, then decrement modes when the PWM value falls below the next, etc...
Any ideas why this is happening? Does LVP work ok for you in this firmware? Almost seems like reading ALT_PWM is not working well, or something...
Edit: This is a pretty good fuse setup web app for the ATTiny13A: engbedded.com fuse app
Interesting. It could be a fuse value, perhaps, since I didn’t change anything except the memory method and fuse settings. Or it could be a bug inherited from STAR_off_time. The fuse values were copied from alexvh’s posts, but I’m not sure why some bit changed. I suspect that 0x75 and 0xfd should work, but I’ve only actually tried 0x79 and 0xed. Perhaps I can test LVP with various fuses soon…
Ok - I fixed it now. First, I re-produced it on another Nanjg 101-AK-A1 (short story: 1st light sold as soon as I showed it to someone...). This was a 2.45A build, but same exact firmware of STAR_NoInit. It has the same exact problem, but this time I notice after the 3 blinks, it actually turns off for a couple secs, then turns on at a moon mode level -- weird.
So again, I studied the code and only possible issue I could see is the manipulations of ALT_PWM_LVL, which is really the I/O register OCR0A. So, I added a variable called: 'setPwmOut' that mirror images the PWM output, and referenced it instead of ALT_PWM_LVL in the LVP code. Then viola!! Re-built and works perfectly. You can see it now go thru 3 blinks, then drop, repeatedly, which is how it should work. Also I fixed a potential bug in the Main LVP code where mode_idx is decremented where it could potentially be 0 before the decrement.
The decrement is below this comment (code inserting sux in a thread post), add an if " if (mode_idx > 0)" before "mode_idx++":
// See if we should change the current mode level if we've gone under the current mode.
Ohhh - I use AtmelStudio 6.2 with the optimized for size setting - all same compile/build settings as my eswitch and STAROffTime projects which work well, including LVP.
