LOL
Nice coiled tape of tiny little emitters. Purdy cool!
Now, do I start testing or start shipping?
LOL
The things I’m most interested in are the Vf and how much the tint shifts with a dedome
Hey Dale, sent me a couple of them and The Sphere ’o Many Mysteries can measure that…
Shipping with right hand and testing with the left one?
Really be cool to see the stats that you can measure.
I’ve got a lot of these to spread around people, speak up, don’t make me eat Ramxpe noodle soup!
$1.72 apiece, that’s the price I got em for by buying 50. A couple of folks have spoken up but y’all need to clean me out on these.
Yep, I’m definitely in for 2. (yes, I know, only 2)
I have 4 in the gas.
We’ll see.
Looking forward to the results!
Did you do any preliminary testing on color and tint?
What were these binned?
Gas? Blasphemy.
Correct me if I’m wrong. I just looked at the Cree Product Characterization tool a little while ago. It has specs for the various emitters and there are three columns so that you can compare multiple emitters to each other directly. I chose: XP-G2, XP-E2, and XP-E2 Torch to compare. I see that the XP-E2 Torch is rated for higher amperage than XP-E2. But, other than that, the performance is not as good as the XP-E2, and not even close to XP-G2 when you measure in lumens-per-watt. The XP-E2 Torch also has a significantly higher Vf than either of the others. Really, what is the draw here? :~
Edit: I should say, total lumens output is higher than XP-E2 because of the higher Vf and being rated for higher amperage. But, really, is the XP-E2 that much smaller than XP-G2? Because, the lumens-per-square-mm would be the only advantage I can think of that this thing might have.
OMG! These things are TINY!
About an hour in the gas, I pulled em out and dome was sitting top but easily lifted right off. About to mount em on 10mm SinkPAD’s….
Maybe a touch early on the de-gasing?
Looks to me like you lost a bit of corner phosphor on each dome, not enough to notice in a reflector light but maybe visible in an aspheric.
I thought you weren't using gas anymore.
The bond wires are on the corners, not missing any phosphor.
I was referring to these little patches of yellow stuck to the domes. Seems it’s a bit of phosphor coming loose from around the bond wires maybe?
You are clearly not used to the xpe size :-)
@David: this emitter is not about efficiency, it is about light per die surface area. And that should be ~20% more, compared to XP-E2, as I understand.
(still in for 10 of those..)
Dale, you definitely lost some phosphor there.
I got mine Wednesday but still haven't had a chance to test them. I need to get some other stuff out of the way first. I'm awaiting your results as will djozz.
I can not wait for these to be in torches. I would pay to uave one put in my a60.
Yeah, I looked at 100% and there is some phosphor on the dome, from the corner right at the bond wires. Looking at the emitters I can’t see any missing, but it’s there on the domes.
OK. I am building an XP-E2 Quad in an Eagle Eye X6. I have it running, but not assembled. A Sanyo UR18650FJ rested at 4.19V will give the quad a little over 5A direct wired, no driver. An LG HE-2 give over 10A and it’s too much. They change tint and output starts dropping. They are 10mm SinkPAD’s, on almost 10mm x 31.7mm of copper sink. Still missing the copper sinks I ordered from Nitro, that will let me complete this and give me that extra .30” of sink. The quad optic is not the usual 24mm Carclo, but a 34mm Ledil with an 11º beam.
This is holding the optic on the head of the light, and holding the wires onto a Sanyo cell. I had to change camera setting for the close proximity and light colored brick wall, and yes it’s daylight outside but the room is fairly dark with those blinds closed. Decent idea how the beam profile works though, de-domed under this Angie optic.
I measured 42.25Kcd with this set-up.
What do you think of the tint dedomed?
