My 7135 driver has low light warning(light drops at 5% i think) but it does not cut off. Maybe with costum firmware it has low voltage cut off. Yes that could be easily done but it will not be practical. Since I am hunter I really don't get why more manufacturers are not making similar 2x18650 flashlights like one below
But such design should also be good for regular flashaholic - you can add pistol grip below and fry everybody at 450 kcd for a least 40 minutes
Yeah I think it is possible and I have thought about this before, but I personally prefer to run it with two 18650 in series so I ended up using LD-4B with another resistor added - And again I don’t recommend anyone boosting the current of the LD-4B until too high.
As for the low voltage cut-off, it depends on the firmware flashed on each individual Nanjg 105C. For example most Nanjg 105C will only give you low voltage warning by dropping the output to low mode and flashing slowly, whereas the Qlite variant will cut off the power eventually. It really depends on the firmware itself, and you can make your own alteration if you can flash these Nanjg 105C drivers. Beside that the low voltage warning/cut-off occurring at 2.8V is just too low IMO, it is not good to have your 18650 discharged until that low of a voltage as it can damage your battery.
Interesting... Who will invent some kind of parallel tubes fur upcoming single cell UF version so we can use 2x cell in parallel? In that case I would also rise number of 7135 chips.
Or maybe some of you guys knows where such aluminum 2x parallel 18650 boxes can be bought?
There are lot of plastic ones on net but I did not managed to find aluminum.
I have been thinking recently about 2x18650 tube side by side(parallel) and below that picatinny rail attachment.
I just cant think of how to make functional version of that for quick and safe swap of batteries.
But now I am thinking on your idea in small configuration. Lets say we have 3x phone batteries in parallel(6000 mah) in some home made small aluminum case on which we can mount UF head and just connect + - wires of battery pack on driver.
It would be ok for simple on/off action.
I am not sure how phone cells would take 4A or more discharge? Maybe that is way to much for them...
If you are talking about running 3x lithium polymer cells in parallel, that could possible work at 4A.
But i haven’t tried anything like that myself, but i know some of th RC guys are using lithium polymer & they often need rather high C values, so my best tips is to do some searches on lithium polymer and various RC uses and you should find some more info or discussion on it.
I didn’t realize that some batteries can be discharged until that low nowadays. Interesting, but I still won’t try that anyway just for the peace of mind.
I have 3 questions: 1. If, and I must emphasize the “IF”, if I managed to make a battery holder for 2 18650 cells in a parallel, how much throw could I get from a dedomed XP-G2 driven at the highest current ? Would it be worth the effort? Would it be a better solution than using a 1504 on 1x26650?
2. I have a trustfire tr-j19 with dedomed xm-l2 u3 1a leds I think? driven at 5 amps. What would be the THROW of a modded 1405 compared to my modded tr-j19?
3. I want a budget friendly throw monster. Is this one heck of a thrower I need or should I try something else?
The output of the XP-G2 is determined by the current going into it (and some other things, but let’s ignore them first). So if I assume that the LED current is always 4A, in this case whether you use 2x18650 in parallel or a single 26650 it won’t change the output at all but it is just a matter of runtime (total battery capacity you have). If crappy battery is used which cannot sustain itself at high current then it is different story.
2. Depends of what kind of configuration you have with your 1405. The modded 1405 can out throw your modded J19 easily if everything of your 1405 is geared towards maximum throw. FYI my modded 1405 is putting out 360kcd, and some even have more than 400kcd. I suspect that the lens quality might be one of the variations here.
3. It really is the longest thrower for the money currently, given that you know how to mod.
The Trustfire tr-j19 is a triple, each led has a small reflector. It is a flooder that produces a ton of light, way more than your UF-1405 will have.
But if you talk throw, I estimate your Trustfire throws well under 100kcd, the UF-1405 with a dedomed XP-G2 at 5A will be 400 kcd.
EDIT: I looked things up and apparently I underestimated this Trustfire, I just now see that Johnnymac did a mod on the Trustfire tr-j19 that resulted in 200kcd, so I stand corrected for my estimation of under 100kcd: http://theflashlightforum.com/index.php?topic=304.0
maybe a pointless question, but is there really no way to modify the pill or some other parts of the flashlight to accept 22mm drivers? I mean this part which holds the driver. Is it possible to cut off the protruding part that holds the 17mm driver and replace it for some adapter ( like a metal tube with inner diameter of 22mm cut to the correct height )and glue it there with a JB weld or some permanent threadlock glue? I somehow can not stop thinking about it If there is a way to make it work with a reliable 5a driver on 2s, it will be the first thing I will buy when the dollar/euro exchange rate gets better.
I can, here are a couple cruddy cell phone pictures. One is the business end of the mod, the other is the light it’s in. The aluminum ring on the bezel is there to protect the aspheric lens I put in with a shorter focal length.
I used Arctic Silver adhesive to hold everything permanently, but the copper shims dug in slightly as everything was pressed together, so electrical conductivity should be good long-term. Soldering the driver is the hard part, even pre-tinning the edge of the copper tube doesn’t quite make it easy. The heat gets pulled out so fast I end up having to go over it with my butane torch to make sure I don’t have any cold solder joints.
