I saw a comment on which light to include in their BOB, and someone mentioned that alkaline's don't leak unless WAY past their "freshness date" printed on the battery itself. That made me go back to the trash can and retrieve the battery I photographed. On the side opposite the leak the "use by date" is MAR 2016.
I can't speak to them being real Duracell's or not, they were on sale at my local "Home Depot", big box store.
parkerdude, 99% of my batteries that leaked were years before the expiration date except those batteries that came with my 2006 CD player. I couldn't read anything on them. They were that bad....
All this just happened, my mouse survived, software said that the battery was low (I had just replaced them recently), so I checked them. I've got 2 Mini-MagLites that just died, they were loaded with the same group of cells.
Maybe I should contact Duracell and see what their position is about compensation. I'll see.
Dang so sorry to hear....i use a logitech mouse with two powerex's in it and they last for months with just one charge......i never ever use alkies because they do leak, and when they do it seems to be in something expensive. I like the wt. of the mouse with nimh, with primary liths my mouse was all over the place...lol. Yes send them an email or better yet call them, because i remember the Energizer 2500 cells and they sent out coupons to get another set of rechargeables that they make.
No Pare, i can not believe you just said that lol.......If it had to be wired i would get a trackball, have one at work and love it, but like the freedom of having no wires. Please keep us in the know about the batteries.
You guys that have Duracell batteries that have leaked or destroyed devices or lights need to take pictures of the batteries and the item it damged and send it to Duracell. My hunch is they need to be made aware of it and want to be made aware of it. And I believe they will make things right with you.
I won't leave alkalines in anything of value for long. I may use them in some lights to run them down, but I check them quite often.
I have had several things ruined or almost ruined from them. If one leaks and ruins something, save the batteries, take some pics, and contact the manufacturer. They will often reimburse you.
I've had lots of stuff get destroyed by leaving alkalines in items that aren't often used. However, I have never had a clock or remote leak when using alkies. So that's about all I use for them.
So if you use LSD, "Lysergic Acid Diethylamide" for the past 3 years or so, how do you know that your alkaline batteries don't leak, you might just be trippin'. You know, a case of "drain bramage" 8-)
dobermann100
I don't think that switching to a wireless mouse would be of great benefit since I already lost 2 rather new Mini Mag-Lites and one that I've had for years, and saw evidence of battery jacket failure in my digital camera as well in the last 2 months.
What frustrates me the most is that I've lost lot's of electronic gear over the years and chalked it up to my fault, leaving alkaline batteries in place too long. It wasn't until the last couple of years that I started buying alkaline's in larger packages to have time to see failures while still working from the same lot#'s.
I'm doing my best to move away from alkaline's from now on, be it rechargeable AA's or products that might use lithium's instead.
My experience with them is that if they were left in devices that are not used for a very long time they will most likely leak. My analog MM, childrens' toys, old plastic flashlights, etc etc. Not used, stored, leaked.
