Thanks!
Nice…the groove came out cleanly!
Awesome job!
It’s also plated all the way through on the 3 copies I got. It seems to be a great solution to the problem of the large omten on a 17mm board.
Did you try fitting a switch on the board? When I put that slot in I wondered if it might be annoying to get the switch’s tab aligned to go through the slot. Tab bent at the right spot.
I can see what you are saying, but no I haven’t tried it yet. I’m still waiting on the switches and clear boots to be delivered.
20mm
https://oshpark.com/shared_projects/UxcU5aMH
I went for a second slot. :party: I liked the idea of slots so that we can solder the switch in from the spring side and keep soldering iron away from the plastic switch.
I’m debating if it might be nice to move the resistor and / or led out, away from the switch a bit. Moving the soldermask (or lack of soldermask really) for through hole led is a bit annoying.
Ordered!
Hopefully the $89 “Super Swift Service” is worth it….
$89 super swift? Really?
Do you hate waiting that much?
One of my favorite things with oshpark is free shipping.
Yikes…you paid $89 for 3 $3.10 boards?
daggum!
Honestly I would recommend against super swift, asking if oshpark can cancel it and refund you. Oshpark custom service is pretty good. support@oshpark.com
The plated slots are not guaranteed, not officially supported, meaning each time you order a board that has a plated slot there is a risk that the slot will not be made. Even if it was made correctly in a previous order.
Oshpark: Internal cutouts and slots.
Even if you do everything right the fab can miss it.
Oops, guess I missed a winky face somewhere up there
I bet there is a very good chance oshpark can cancel it and refund you. Just email them at support@oshpark.com
Oshpark custom service is friendly, there is nothing to lose.
Do you mean you were just joking, and did not pay for super swift?
If so, you got us!
Lets have a look at these clear switch boots, I’m interested in the idea.
Transparent tail caps are available at cnqg. cnqualitygoods > Tail Cap
Haven’t seen anyone else carry them.
:bigsmile: :party:
Oshpark just made my day!
Here is the email I just got from them:
Hi! We had some free room on one of our Super Swift Service panels,
so we took the opportunity to give you an upgrade.Your affected orders are:
* Tail switch with led 20mm copyThe Super Swift Service drops your expected fabrication time from 12
calendar days to just 5 business days. The same fabs manufacture the
Super Swift panels as our normal panels, so you can expect the same
excellent quality.Only fabrication time is affected, so the shipping times and method will
remain the same.Thanks for using OSH Park!
Shall see how this project goes. Might need to get some of those.
The basic concept is tested as working, but it definitely takes some tweaking. You’ll need to slightly modify your driver in addition to having this board. Read this thread for more info.
My clear caps made it to Chicago, so they should be here very soon. I’ll post pics when I get it fully assembled.
This is pretty cool. So good to see you and Helios- turning your idea into reality.
Now that I am nearing the completion of a project, I will order some of these boards and experiment with this too.
