I'm actually surprised that this thread does not attract more attention. It is not that I invented the wheel (comfychair did), but this easy single-sided driver version has everything that wight's beautiful 17DD single-sided driver has (single-sided, DD, low voltage protection, reverse polarity protection, great direct electrical connections from battery to ledwires -better than a 105C-, programmable MCU) but it comes with extra's:
-dead cheap
-only two parts have to be sourced which are available for everyone around the globe
-you can flash new firmware, but if you don't it comes ready with NANJG stock firmware which is not the worst of UI's (high freq.PWM, alright mode groups)
-if you keep the stock firmware it is an easy three minutes build with just a solder iron
But I admit it does not look as handsome as a wight-design on an Oshpark board ;-)
At least it DOES attract my attention. I know what these things can do, simple yet effective and thanks for helping us to document these information here again.
The only “problem” for me is I am not sure which FET has the low resistance which I can access to. Thank you Major for reporting this to us and I am going to order some of these later.
You got my attention - but as I'm new to modding and electronics, I don't understand half of it :-P
I sometimes start reading topics as they sound interesting, but quickly have to give up because of a lot of technical stuff, and a lot of abbreviations ;-)
NP (No Problem) It just mean a bit more googling. Didn't mean to bring the thread OT (Off Topic)
Actually no problem at all. I think it's "healthy" having to google some stuff. Takes a little extra time - but the stuff you learn by searcing yourself, rather than having it served, sticks better to memory. I actually hate when people expect to have everything served. So no problem! Alread learned a ton from BLF.
Im sure you have the attention of many others, including me. :bigsmile: Thank you for posting such a great inexpensive mod. This is something that almost anyone can accomplish.
Quick update, I'm excited about this driver mod it's so easy and cheap.
I modded an old knackered ak47 driver last night and the PH4030 mosfet fits easily, it's so tiny it's incredible, it's thinner than the attiny13, I was worried about losing it in the weave of the carpet! The solder pads line up perfectly.
At five amps output it was running cold and had modes. Voltage drop across the mosfet was a lowly 25mV in high mode.
Winner winner chicken dinner.
Im looking for some for duel channel firmware to try this is begging to have a AMC7135 fitted.
Great to hear that the voltage drop over the FET is only 25mV@5A, that is nothing to worry about: the average steel spring has a voltage drop of 250mV at 5A!
I had not thought about that possibility. You can keep the 7135 'around the corner' for that, but you will have to cut the trace to the MCU and air wire it to a different pin I guess (I have not looked into the pin-layout of Toykeeper's dual firmware for the EE A6 group buy driver)
Back in 2012 I posted This thread about an alternative way to use attiny 13A/7135 drivers with higher voltage series cells for series LEDs. At that time a few others were doing Zener mods and none of the Oshpark boards had been done yet.
In 2013 I asked Mattaus to design a 10mm driver using the Attiny13A and one 7135. He had created other boards by then and so had others so the Oshpark projects thread was born.
A bit later Brian(WarhawkAVG) asked me to collaborate with Mattaus and Comfychair on another board that combined the Attiny13A with an FET and the BLF DD family of drivers was born. I hadn’t really contributed much in the design of them but I did suggest using the LFPAK56 for its small size and high current capability. We ended up going with the larger FET because Comfychair who was doing the lions share of the testing had a lot of them to work with.
With the concept proven wight began developing designs that took advantage of the smaller FET size to make single sided drivers and that has now progressed to multi-channel drivers.
All throughout this time a bunch of truly inspired people(literally a who’s who of BLF) have been developing and tweaking the code for the 13A mcu to take better advantage of the new board designs.
We now have a member who (RMM, Mtnelectronics) who has set up shop and along with much of what one needs for modding sells many of these designs as well as coming up with new boards on his own.
DrJones, TomE, ToyKeeper, I can’t keep track of all the people writing and developing code and there are a slew of people now with more joining in adding their 2 cents. I didn’t start this but it sure has been fun to be a part of.
Edit- this post is not about claiming any credit, that all goes to Matt, CC, Alex, Brian, and all the others that pushed to get where we are now. It is just how I came to be involved and my perspective on the process.
very nice ,espacially when it does not need programming ,to make it even cheaper ,will it work with the 3 leg FET ? (salvaged old vgas and motherboards have lot of them)
FET-specs are beyond my understanding, but I'd just try some out, as long as you can make them fit. Those 3-leg FETs have long leads, they canbe bended to anywhere I suppose.
Oh, and thanks Rufusbduck for the short history of the BLF direct driver builds :-) . I had the pleasure of watching it all a bit from the sideline, these developments I think are among the absolute highlights in the (short) history of BLF (at least in the period that I have been a member).
So I was looking at NXP’s (the FET manufacturer) videos on YouTube and when they said they are at Manchester I laughed, that’s like 30 miles from here! And I’m buying their transistors from China which is thousands away, crazy world.
I used to wonder why we can buy CREE LEDs from China at relatively low prices considering it is American company, then I came to realize that CREE has manufacturing plant in China.
Another similar story is that Samsung does operate a battery manufacturing plant in my country (known as SDI) and the plant is only 30km (18.75 miles) away from my home. But since they only produce for exportation purpose we don’t get to buy them any cheaper or any more conveniently. We still have to buy these Samsung batteries from China and waiting for month(s) to get here.
