Um… does anyone ever advise you that HID takes awhile to reach their full potential power and after that it’s only last about few minutes before it shutdown due to heat?
how about nitecore TM36?.. you can see way past 200 yards
Al those Fenix super throwers with XML2’s even dedomed and pushed at 6A just are not as impressive to me….yeah, you get 400K lux on some or more, but with 1500 OTF lumens in years past I would be impressed. However, now with my MTG2’s at 40~45watts with over 100K lux, its just no contest. Hence; why I gave up on LED’s for now.
I strongly considered an FF4 and continue to do so. There was some talk about an FF5 with active cooling and other upgrades. If you look over at the other place, there are many complaints about reliability and inherent design flaws/limitations. IMO, its not ready for prime time and still needs a lot of work. Hopefully the FF5 will come to fruition one of these days, or someone builds a reliable similar HID in the same price range and form factor.
Really!!! My TK61vn V4 is ~ 750Kcd and ~ 1800/2000 lumens,you can’t beat the throw for an LED reflector based light. HID or LED, I do not think you can get a combo of 700Kcd and 5000 Lumens.
My favorite is the TK75vn,~ 3500 lumens and 341Kcd
I knew Alex GT would chime in.
Seriously Big C, order the darn light and pay for extra fast shipping with tracking. You could have a FF4 in your hands in a week and be wearing an ear to ear grin.
Just do it. Stop beating around the bush.
Is it that good?
Yes!
I wouldn’t get too concerned about having an extra bulb for the FF4. Normal life span is 1000-2000 hours depending on how hard you push it. I do not think 1000 hours total burn time at 40 watt setting is unreasonable.
The bulb alignment in the reflector is crucial and this is something you want a highly trained and meticulous type of factory tech/optical assembly expert to tackle.
I have an FF4 too. It does project a very bright, very far and wide beam of glorious light…. more than any multi-emitter light I own (stock and modified).
But…if it’s the only light you will own (and I doubt it is), then it’s an impractical beast to use as it eats batteries like crazy with a 2000-lumen low mode and can fry an egg…
A flashaholic should own a good HID though…it’s a different animal, so to speak.
Yes, I am aware that it exceeds the factory rating of a 2000-lumen low mode @ 24w, as well as the other modes for that matter, as tested by RDfronty, if I remember right.
As a former owner of this light, the 60W version, it was great, but has some serious issues;
1. Lots of issues with the battery carrier for many people. I had to send mine back for repair.
2. You can only enter turbo ONCE after which you must turn the light off in order to enter it again.
3. In a warm environment even the low mode will get too hot.
4. Eats batteries fast.
5. Once you do a turbo run, you will need to allow it to cool down.
6. If the light gets HOT, you will want to turn it off, preferably take batteries out, and it will actually get hotter before it cools off, so it's out of commission for ~10 minutes or so.
7. Like all HIDs it needs to warm up.
Don't get me wrong, I like it, and I certainly don't regret buying one, but having had it, I can't help but to think LED lights are superior in most applications.
If an FF5 with active cooling, and carrying 8 batteries instead of 4 came out, I would grab one, but until then the FF4 just isn't practical to me.
As an alternative, I very strongly suggest getting an Acebeam X60, dedomed, and with a current bump. You'll get ~6000 lumens from it, and ~500kcd.
A modded RC40 would also work, but the price tag would be steeper, and output not quite as high.
Wow! That is a lot of negatives! I learned more about HID lights by reading your post and others.
I would NOT even consider one just on these THREE points alone!
6. If the light gets HOT, you will want to turn it off, preferably take batteries out, and it will actually get hotter before it cools off, so it’s out of commission for ~10 minutes or so.
It is more than “Maybe 1500 OTF” and probably 100 lumens or so under my 2000 estimate.
Mine is updated from the V1.9 “Prototype” and is the “V4” version.It has a revised driver I believe RMM designed with thermal protection and driven a little more. It is probably 1800 to 1900 OTF! Hopefully Justin will get this version to test and verify output.
Here are Justins[JMPaul320] measurements of the PROTOTYPE.
Other than the cosmetic changes which are minimal. They use the same exact bulb and its said to drive the bulb slightly more current with the 65WATT difference. I was also told lux is unchanged and the lumen output is negligible.
