I wonder what it would take to have a red, yellow, green (or whatever color you wanted) to activate at certain voltage levels…aka tail cap tells you the voltage
I know simple is better but just brainstorming here…
Wait…if it has enough power to run the LED, why would it not be enough to toggle a MOSFET?
Have you tried 2 red LED in series? The voltage could probably be enough for them and you would get low voltage protection this way…
P.S.: I’ve thought about this - beside 2 LED’s you could also use one or more ordinary diodes (like SMD 1N4148) in series to the tailcap LED (s) to adjust the cutoff voltage to a useful level - thus getting a signal for low voltage as a bonus (LED goes out).
the 805 SMD red leds that I found are all 2-2.2V, my first thought is that two in series would give a 'your battery is not completely full' warning :-) . But at the sub-mA currents the voltage may be well lower than that...
A typical Si diode (1N4148) would add about 0.6 Volt to the LED’s own. For the real cutoff voltage of the different options (1 or 2 LED and 0…2 diodes in series) it would be best to test it (outside the flashlight?) with a variable power supply. So you can find out when the LED goes off by decreasing the power to lower levels - the current should go to zero if the LED don’t shine anymore.
You definitely can’t discharge the cell to a lower voltage level than the sum of the forward voltage of the diodes. The forward voltage in the data sheets is taken at the nominal current, the minimum voltage to lit up is lower! Unfortunately for this application there is no abrupte transision between “on” and “off” - the led will get dimmer more and more with lower voltage until the minimum is reached.
I quickly did some measurements to find this minimum for different LED’s:
With 4k7 resistor (a bit lower value could be better if the diodes claim more of the battery voltage for their own) in series:
white 5mm LED: below ~2.5V to shut off
green 5mm LED: below ~2V to s.o.
red 5mm LED: below ~1.6V to s.o.
2x red 5mm LED in series: below ~3.2…3.3 V to shut off
As I suggested, you should try 2 red LED’s in series to get best results:
- no discharge to critical levels by the tailcap feature
- optimal use of energy by two LED’s instead of one (losses in the resistor decreased)
- signaling of “low voltage” if the LED’s go dim/out
one LED on each side of the switch for a more uniform illumination
The red XP-E2 starts emitting at about 1.7V, perhaps this is similar for a red 805 smd led (I have a few on order, I can test that ). Adding two diodes would make that 2.9V. If there are no further significant voltage eaters in the circuit (?), that could be quite ideal as a voltage indicator.
A little bit of the battery voltage is claimed by the 560 Ohm resistor on the driver. As I said, it would be best to take measurements with the actual setup.
Blue LED’s are similar to white ones - the little voltmeter modules I just bought are shutting off below 2.7V with the blue display. You could add one 1N4148 (or LL4148 for SOD80 package Redirect Notice) in series with the LED’s.
Yes, these are multi-purpose for smaller currents up to 200mA. They can be used on different applications, to reduce the voltage by 0.6 Volts, as rectifier or protection diode. But you could try almost any other Si diode first if you got some in your spare parts box or salvage it from an obsolate circuit and order them later when the setup is finished.
I don’t have many spare parts. The only diodes I have are LED’s, SS34 schottkeys, zeners, and the reverse polarity diodes used on all of wight’s drivers.
You could use one the zeners you have, just in the forward direction (rather than the usual reverse for zeners), its Vf will be ~0.7V just like a standard diode. Obviously the reverse voltage will be whatever the zener is rated at, but it won't matter as it won't see any reverse voltage.
