Yes
I have a problem with the Offtime memory. The driver change the mode with first clic even though I cut off the power for a few minutes.
I changed already OTC capacitor, just to be sure it is right value.
Other features seem to be working correctly.
I am using layoyt v0.24 and flashed with star offtime v1.2.
seepeli, can you take a pic and show us your driver? Makes it a bit easier to figure out what’s going on…
I’ll take a picture when I get home.
Sounds more like a bad/dead capacitor, Do you have a DMM with capacitance option , measure the capacitance individually.
If not, remove both capacitors, put fresh ones, preferably from a different batch.
has anyone been able to use any version of wight’s boards with a zener mod as was intended with the design layout? or has everyone had to stack c1 and the zener diode together? does only RMM/MTN’s board work with a zener layout as intended?
I measured both the capacitors capacitances and they were OK. I installed capacitors back and I got OFFTIME memory to work. I may have originally installed the capacitors the wrong way?
In any case, the driver works, so thanks to all!
Those caps aren’t polarized so something else was iffy.
I meant that the capacitors may have been on the wrong places, not in the wrong direction.
Sorry for the bad English
Built my first one of these today. Had some issues at first I couldn’t get it to work checked every thing, diode direction, shorts ect… but could find any thing then I thought it might have been the firmware I flashed it with so tried a different one just to find out it couldn’t flash to the ATTiny13a I was using, swapped it and and hey presto it works.
Its now in a C8 with 25R powering two modes just need to get a dedomed XM-L on copper to finish it off J)
Good work getting your first one to work, that’s mostly the hardest part… Cheers!
I tried one Here and it seemed to work ok but I didn’t pursue testing because I didn’t want to accidentally damage an ‘expensive’ fet, while the cheap ebay ones didn’t matter so much. Well, it was expensive, now they are offering free postage grr.
HI all,
Once again it seems vesture is struggling to tread water in the shallow end.
I have used a lot of these drivers with the zener mod and they seem to work fine, but for some reason I have yet to be able to get a working single cell version.
Here is my board.
With this exact setup I get NO light what so ever. I built 2 identical boards to make sure it was not a bad component.
If I replace the 19.1K resistor at R1 with the 36K resistor used for the zener mod I do get light, but when I change modes into the higher up ones it stays there for a second or two and then cascades back down to the lowest mode.
I have tried this with 2 different firmwares and the results are very similar with each.
The boards and the FET are from Mountain electronics so they are proven components.
Any stab would be helpful :)
are the capacitors in the right place? C1 should have the bigger one, hard to tell from the pic
I agree it is hard to tell from the pic. Yes I did at least have that right :)
Hard to see, but are you sure that the C1 capacitor is the correct value?
How bout the diode - is it in the correct direction? A reversed diode would kill it. Also for LVP, I don't use the 19.1K, I use the 22K's as listed in the OP.
No, I'm not certain. The smaller one came from you, but the big one is mine from a batch of custom 7135 boards. That, the 19.1K resistor and also the diode were mine. Here is a pic of the PN.
Ahhhh- why is this board layout you have completely different from v024 in the OP? What is the board you are using?
What is this mystery board??? Anyone?
