Sorry, I meant Nanjg 105c with an otc installed. I was just hoping to use some of the advanced features of starry-offtime but was unsure about the secondary channel bits. I'm currently running STAR offtime on the driver in question.
Ah, okay. It should work then. But if it has only one power channel, you’ll want to use only the primary PWM (MODESNx, not MODES1x, and swapping the fast/phase defines like you already did).
You might also get more mileage out of the blf-a6.c or tk-otc.c firmware, which are similar to starry-offtime but more mature. But you’ll need to adjust the ADC values for offtime and voltage (which can be measured with the firmwares in battcheck/* or copied from reference values).
It also currently requires changing a line of code in the battery check mode, but I’ve been meaning to fix that for easier use on single-channel drivers.
I appreciate it! I'll give the blf-a6 and tk-otc firmwares a shot. I presume I shouldn't try to use the battcheck mode on either firmware with a single-channel driver for the time being. (I'd change it myself if I had a clue what's going on... but I don't. )
Oh, it’s a simple change. Look for the “void blink” function and change its set_output(0,20) to set_output(20,0). This moves it from the second power channel to the first; otherwise it won’t light up at all.
But I have a few other improvements to make too…
I know it’s written in here somewhere, in several threads I guess… Anyway, when is phase correct PWM preferred over fast PWM? If I understand correctly, phase correct can produce some noise. But as the possibility to select it exists in a lot of firmwares there has to be a situation where it is beneficial. What would that situation be?
Phase mode is helpful to get moon modes between what fast mode provides. It also is required to make the emitters shut off completely in some cases on e-switch lights, because fast PWM still emits even at level 0 on some drivers. It is also less sensitive to low batteries, so the low modes won’t sag as much. And some people just prefer it, despite the whine and slower flashes.
Thanks for the explanation, I’ll test it someday. It makes sense except for one part. If one wants to shut off the emitter completely, why not just turn off the pin?
It would probably work, but it’s usually easier to just set PWM=0. Fast PWM will still output a brief spike even at zero though. IIRC, someone also tested a slight difference with PWM=255, where phase was slightly brighter than fast (fast has a brief downspike even at 255, I think). So as a general default, it’s usually a good idea to use phase at moon and turbo but use fast for everything else.
Adding pin logic is untested, I think, and would use a bit more room in an already-cramped space. It’s also redundant if there is already logic to put the MCU into sleep mode while “off”.
I suppose it’s a minor issue at worst, so nobody has spent much time on it.
To turn off the pin only one additional row of code is needed, but I guess your right with it being not needed. Thanks for taking the time to explain it.
Guys, Is there 1 mode-100% ( or star choosable 1 mode) 105c firmware awailable guys? Currently i am bypassing the atttiny13 in order to achieve this , and ofc warnings and cut-offf are lost this way
Hi Mitko,
I have a couple of “1 mode” firmwares you may like;
- 100% only, with Low Voltage Protection enabled (will flash 3 times & drop down to 30 (out of 255) output when 3.2v is reached).
- 100% Turbo for 2 mins, then steps down to 110 (out of 255). Retains LVP as per above.
These are for Clicky switches.
I can throw them into Pastebin, or email them to you if you like.
Isn’t 3.2v too high?
Can you send me these files too?
When using a zener modded board for use with an MT-G2 do we need to just adjust the ADC values or swap out the resistors as well to get it into a specific range?
You should be able to do that in many of the available firmwares, simply by removing all modes except turbo. This is generally done at the top of the file by changing or removing #defines.
For example, in STAR, I think all you need to do is comment out the “MODE_*” lines except for “MODE_TURBO”. This should give you a light which is 100% or off, with gradual ramped step-down to about half power after the light has been on for a while (default is 2 minutes).
It appears that the code will also step down by half each time the voltage is too low, except it won’t go below the lowest level… which could be an issue when there is only one mode. You can probably fix this by hard-coding a minimum instead. This is untested, but here’s an example of the changes needed:
<code>
(there was a diff here, but it didn't format correctly and was untested)
</code>
Edit: The forum doesn’t seem to like raw code and is reformatting some of it incorrectly… instead, try going here for a 1-mode version of STAR which I tested on my bench power supply to make sure LVP works:
http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/files/head:/ToyKeeper/STAR_1mode/
Both. Your voltage divider must also read directly from the input source, since reading after the zener diode will always give you the zener diode's voltage.
@TK i hope this question fits here if not, please someone direct me where this is more appropriate
I have been thinking about if you only want a nice low moon/max of one 7135 chip/and full blast DD in a driver, do we even need an FET for this?
Couldn’t the attiny13a simply connect the battery to the led & and shut down the 7135, similar like what DrJones did in his “Glow” driver
But instead of a glow mode from “An additional 100k resistor bypassing MCU and AMC7135s, while the MCU switches the 7135s off” you do the same but without the resistor to get full DD on one channel & a nice regulated 7135 on the other.
And another idea if you don’t want/need the max possible output from the FET driver PWM level 255 for max amps, could you lets say start at a lower percentage, for example PWM level 128 and then pseudo regulate this so that when the volt drops & amp drops it automatically raises the PWM level to get a stable regulated output from a FET driver?
I’m trying to get LVP working on an MTG2 build.
I am using 22kohm as R1 and 2.2kohm for R2. I ran TK’s battcheck with my power supply at 6.2v and it spat out a value of 136, and 130 for 5.9v.
I plugged those into STAR offtime, flashed the driver, and reconnected my PS.
I started at 6.4v and slowly lowered the voltage and…… nothing happened. I let it run at 5.5v volts for about 5 minutes and LVP never kicked in.
I reflashed and retested again with the same results.
I gave up and put batteries in the light to use it that night, and immediately LVP kicked in. I removed the batteries and checked them, they’re both at 4v.
Any ideas what’s going on? Do I need to set my PS to a higher current?
DD directly through the attiny would blow it in no time. Remember: V=IR (think of the attiny13a as a VERY high resistance switch).
To fully regulate current you need a sense resistor (with additional losses), but you could alter PWM based on battery voltage as well (I think that someone has already tried this).
Were you measuring the power supply output with a multimeter? If the current is set low, then the voltage will automatically drop down to the voltage needed to maintain that maximum current.
I think that's beside the point though, since your values are in the ballpark. Your batteries might be sagging down to the LVP level.
I have checked it’s accuracy with a DMM, but not at the time I was doing this. The ‘Constant Voltage’ light was on at the time. I don’t think it’s battery sag, because it kicked in on low mode ~350ma.
I was using a FW that previously had LVP disabled, so maybe I messed with it more than just commenting it out and don’t remember now. I’ll retry but starting with a stock FW this time.
edit: just redid the battcheck with dmm this time, and got the same values.
