This light does not include in-light charging, does it? Looks good.
Doesn’t seem like it has in-light charging, but I wish the mode spacing was a bit more like this.
Level 1 : 0.9 to 0.9
Level 2 : 300 to 50
Level 3 : 1000 to 250
Level 4 : 2000 to 1000
Level 5 : 3400 to 2500
Level 6 : 5000 to 5000
LED: Cree XHP70-LED mit einer Lebensdauer von über 10 Jahren Laufzeit
Max-5000lumens-Ausgang (4 x 18650 Akkus)
Ausgang (nach Magnetring auswählen):
Stufe 1: 0.9lm(1200hrs);
Stufe 2: 300lm(320hrs);
Stufe 3: 1000lm(35hrs);
Stufe 4: 2000lm(16hrs);
Stufe 5: 3400lm(6.9hrs)
Stufe 6: 5000lm(3.2hrs);
Standby: 65uA
Strobe: 5000lm;
Betriebsspannung: 10V - 17V;
Max Runtime: 1200 Stunden;
Max Strahlabstand: 704meters;
Spitzenintensität-Beam/Ausleuchtzone: 124100 Lux;
Schlagfest: 2 Meter;
Wasserdicht: IPX-8 Standard (2meters);
Größe: 205mm(length) X 88 Mm(head diameter) * 50 mm (Rohrdurchmesser);
Gewicht: 720g (ohne Batterien);
Aircraft Grade Aluminium Karosseriestruktur;
Zubehör gehören:
1 x Bedienungsanleitung;
1 X Halsband;
1 X Halfter;
1 x Ersatz O - Ring und Tailcapgummi;
I
I never charge my batteries inside the flashlight, but I know that a lot people will find that more convenient. If it doesn’t work correctly, it’s better not to have it at all.
Good heads up Flashpilot but I think this model doesn’t come with built in charger…
It apparently affects all of their flashlights with cell carriers. Several BLF members have reported Supbeam/Acebeam flashlights without in-light chargers to show large cell voltage variances after discharge. So its not just the lights with in-light charging that are of concern.
So if you have one with a cell carrier, check your beginning and ending voltages before assuming your flashlight is safe to use.
Isn’t the battery carrier in the “non in-light charging” category just a bunch of connections basically, without any IC? How would that discharge cells differently? I just have a K40M, haven’t checked the cells yet.
That would seem logical to me. :bigsmile: There are now literally thousands of BLF posts spread out across several Supbeam/Acebeam threads. I only own the X50 and X60, both of which have the charging problem I described (with in-light charging).
Since the manufacturer has seriously dragged its feet for a long time while attempted to convince me that their faulty design was acceptable, I hope everyone will wait to see if they will do as promised before buying any more of their products. Also, you might want to reference the K50 GB and X60 GB discussion threads for a better perspective of what you are considering buying, along with the later discoveries of some of their inherent faults.
O come on people, let’s spread some love instead
I like new T25, I will apply for review
For cells in series it is important that they are identical. Otherwise it is possible that one cell that discharge faster may be "reveres charged" and be damaged/vent. But that also depends on the driver, if it has low voltage shut off, and if the cells are protected.
And the same cells (brand/model) with different ages may have been used/abused differently and may have different internal resistance and capacity. So when charging cells that are intended to be used in series it is good to have a charger that can test the internal resitance and capacity so you can verify that it still is the same, or very similar, for all of the cells. If you can't test the the cells, it is safer to only use protected cells.
Of course Adoby, I was assuming all cells were exactly identical. I guess I should have wrote it, seemed common sense to me.
Yes, but without actually checking your assumption may very well be wrong. And you actually said that you haven't checked the cells you use in your K40M.
It is commonly implied at BLF that it is good practice to use same cells (same manufacturer, same capacity, same age and preferably same batch) especially if they are in serial connection.
I think what DanielM meant is that he didn’t checked cells at what voltage level is every individual cell after discharging in his flashlight:
Exactly Sirius9, and I don’t see any reason why the cells in a dumb carrier would be discharged differently. I will check when I get home to add already existing data.
hopefully available as a flash deal like the K40M was…
@flashpilot. After reading this I checked the cells on my K40. All brand new Panasonics, I get 4.06, 4.07 and 4.07. I know they are not very discharged but it does not seem too much of s problem for me so far.
What kind of voltages are you getting on yours?
Marc
The performance are very impressive !
3400 more lumens than K50 with similar runtime (3.2h) but with a little less trow : 124klux vs 140klux. The design look like a prototype though.
Four cells though.
Marc
In my K40M I’m getting exactly 3.83V on all three brand new same batch Panasonic PF’s.
Its about community. So far Acebeam has not met its burden as far as the community is concerned. It would be foolish as a community, to continue to buy Acebeam/Supbeam products from this forum. It says we dont care what they do, the next product just has to capture attention and the past will not matter. You might want to consider if thats what you want them to take from this.
ie: Sell us any shit, at any price, and we will still buy your next over priced release. And it is over priced, these arent $30 lights. At their price point, there should be no design flaws. And righting the wrong of the earlier models does matter.
The forum is a community, and right now the community is in process of trying to get Acebeam to correct an error, one they are already dragging their feet on. Are you part of that community? <rhetorical question.
Well put.
These lights are a sizeable £ outlay, even with a discount, so they should work as advertised, even if people choose not to use all the features, that’s up to them, but we paid well for those features so they should all work correctly
