I never charge my batteries inside the flashlight, but I know that a lot people will find that more convenient. If it doesn’t work correctly, it’s better not to have it at all.
Good heads up Flashpilot but I think this model doesn’t come with built in charger…
It apparently affects all of their flashlights with cell carriers. Several BLF members have reported Supbeam/Acebeam flashlights without in-light chargers to show large cell voltage variances after discharge. So its not just the lights with in-light charging that are of concern.
So if you have one with a cell carrier, check your beginning and ending voltages before assuming your flashlight is safe to use.
Isn’t the battery carrier in the “non in-light charging” category just a bunch of connections basically, without any IC? How would that discharge cells differently? I just have a K40M, haven’t checked the cells yet.
That would seem logical to me. :bigsmile: There are now literally thousands of BLF posts spread out across several Supbeam/Acebeam threads. I only own the X50 and X60, both of which have the charging problem I described (with in-light charging).
Since the manufacturer has seriously dragged its feet for a long time while attempted to convince me that their faulty design was acceptable, I hope everyone will wait to see if they will do as promised before buying any more of their products. Also, you might want to reference the K50 GB and X60 GB discussion threads for a better perspective of what you are considering buying, along with the later discoveries of some of their inherent faults.
For cells in series it is important that they are identical. Otherwise it is possible that one cell that discharge faster may be "reveres charged" and be damaged/vent. But that also depends on the driver, if it has low voltage shut off, and if the cells are protected.
And the same cells (brand/model) with different ages may have been used/abused differently and may have different internal resistance and capacity. So when charging cells that are intended to be used in series it is good to have a charger that can test the internal resitance and capacity so you can verify that it still is the same, or very similar, for all of the cells. If you can't test the the cells, it is safer to only use protected cells.
Yes, but without actually checking your assumption may very well be wrong. And you actually said that you haven't checked the cells you use in your K40M.
It is commonly implied at BLF that it is good practice to use same cells (same manufacturer, same capacity, same age and preferably same batch) especially if they are in serial connection.
I think what DanielM meant is that he didn’t checked cells at what voltage level is every individual cell after discharging in his flashlight:
Exactly Sirius9, and I don’t see any reason why the cells in a dumb carrier would be discharged differently. I will check when I get home to add already existing data.
@flashpilot. After reading this I checked the cells on my K40. All brand new Panasonics, I get 4.06, 4.07 and 4.07. I know they are not very discharged but it does not seem too much of s problem for me so far.
Its about community. So far Acebeam has not met its burden as far as the community is concerned. It would be foolish as a community, to continue to buy Acebeam/Supbeam products from this forum. It says we dont care what they do, the next product just has to capture attention and the past will not matter. You might want to consider if thats what you want them to take from this.
ie: Sell us any shit, at any price, and we will still buy your next over priced release. And it is over priced, these arent $30 lights. At their price point, there should be no design flaws. And righting the wrong of the earlier models does matter.
The forum is a community, and right now the community is in process of trying to get Acebeam to correct an error, one they are already dragging their feet on. Are you part of that community? <rhetorical question.
Well put.
These lights are a sizeable £ outlay, even with a discount, so they should work as advertised, even if people choose not to use all the features, that’s up to them, but we paid well for those features so they should all work correctly
As much as they want to fix it right away…it’s not going to happen over night.
Rhetorical question? yeah it is… what kind of community are we talking about? lynching community?
Are we trying to lynch them because they can’t fix the problem over night?
Do you really believe they want to drag on their feet fixing this issue so they can ruin their reputation?
I’m pretty sure everyone here is aware charging batteries is series is always challenging not too mention dangerous.
That’s why I never want to charge my batteries inside the light unless I’m absolutely has no other choice or means of charging my batteries outside the light, even in the event of emergency, then I probably just going to charge it for few hours just so I can use them again.
Even if you have the same batteries from the same batch, sooner or later one of them will discharge more than the others.
So I’m not really sure this “lynching” style of fix this issue or we won’t buy it from you again is really motivation for other company to offer GB of good light at a good price in the future.
What happened to the free will? I’m pretty sure by this time a lot of people are aware about the charging inside the light issue, so if they want to buy Acebeam’s other product, they will do so at their own risk, so what’s the problem? it’s their money…
BLF community is all about sharing information, Regarding how others use the information is irrelevant.
But telling others to boycott the company because their light is not perfect it’s just…“Neanderthal”.
To be honest, there’s no such thing as a perfect light, every other company has their own flaws in their designs.
Are supposed to boycott Fenix for having plastic reflector in their premium priced lights?
But boycotting the company for not fixing the problem a lot sooner is the same idiotic scheme as blaming the guy who overly excited to introduce the GB in the first place ( at times makes me wonder…)
And are we suppose to lynch him too for not finding this problem sooner before he started the GB?
Anytime you buy any light… you’re at your own risk, it’s that plain and simple.
If you’re afraid to get burn, then stop playing with the torch ( pun intended J) )
