Put me down for 1 please + extender please.
PS - what about a pocket clip??
I agree. Make it slimmer. A slimmer body as above would work.
I’m waiting for final design
slim body wont work for any trits. only slight knurling is available.
20mm lens, we need 0.5mm space for it. and 1mm for thread. 21.5mm.
2mm thickness for 1.5mm trits. (both sides it will be 4)
21.5+4=25.5mm
So as I understand the complete flashlight has become say 2mm thicker (=17% added volume/weight) than needed to be able to add trits whre they are now. I'm sure there must be more clever ways to position trits if you really want them.
In for 2, both with extension tubes if possible
In with both tubes…
Still a bit sceptic because everything seems to change every few days and no real picture of the end product available…
the pill with be made from brass ? will it take 20mm led pcb or 17mm?
Can we see a picture of the actual light?
I am in, depending on a final sample view.
I'm in depending on the final design! ...
Make the body thinner. The head and tail can be thicker to hold the trits.
I’m in for one.
I’m interested, count me in for 1 with extension tube.
Do the bodies come with drilled and tapped wholes for the clip?
In for one, depending on final design.
Are the trits included? If not, how much will they cost?
Not included. Trits are around $7 each. For 10 trits, $70! Trits are nice, but costly.
Hmm, I’ll have to think about it; I’m just not sure I like the design all that much. At least, probably not $50 much, although it is a steal for a Ti light!
I’m in for two plus…… One extension tube.
I’m in, depending on final design. For the host, 18650 extender and clip!
