the pill with be made from brass ? will it take 20mm led pcb or 17mm?
Can we see a picture of the actual light?
I am in, depending on a final sample view.
I'm in depending on the final design! ...
Make the body thinner. The head and tail can be thicker to hold the trits.
I’m in for one.
I’m interested, count me in for 1 with extension tube.
Do the bodies come with drilled and tapped wholes for the clip?
In for one, depending on final design.
Are the trits included? If not, how much will they cost?
Not included. Trits are around $7 each. For 10 trits, $70! Trits are nice, but costly.
Hmm, I’ll have to think about it; I’m just not sure I like the design all that much. At least, probably not $50 much, although it is a steal for a Ti light!
I’m in for two plus…… One extension tube.
I’m in, depending on final design. For the host, 18650 extender and clip!
the tail will be drilled.
It's in processing now. Machine is a little busy, have wait a few days.
and we're going to have a short holiday. 4th-5th April.
Edit: Not weekend or Easter, it's Tomb-sweeping Day.
copper pill. It takes 20mm noctigan. The top of pill must be flat I think.
If the inside of the head is threaded up a bit farther then when using a noctogon triple and shorter Carclo optics one could screw the pill in farther and use an 18500 cell. Probably need to mod the springs but that’s what we do.
Update 02.04 TLF:
Intress Host:
Xandre
walter01
Ger-slash
urausb
FrankFlash
Bluzie
kiely
Hrcl.-MC2
hitech
Thunderhawk
+Extension 18650:
walter01
Ger-slash
urausb
FrankFlash
Hrcl.-MC2
hitech
Thunderhawk
Regards Xandre
What Gunga said, body thinner than head and tail cap.
Thank you.
