If they are of a standard size and fit some of my lights then, yes please! I’ll take two.
I’m in for one
I’m in x 2
I’m in for one.
I’m in for one.
In for probably 2.
Incidentally Rey, could you make sure that the clip is a heavy enough gauge that it will not bend?
Yes, can you make it as stiff and strong as the first pictured clip. MAYBE a touch shorter or the same length.
2mm thickness should be ok?
I’m in.
I’m in for one.
Seems good. I’ll try to measure my clip soon.
I'm in for 5
I don't know about titanium but the stainless ones are around half a mm.
Im in with clip please…thx
Does anyone own the clip in 1st pic?
I do. I’ll try and measure thickness for tomorrow. If you make it similar and it fits lots of lights, I’ll get 4-5. Not sure how it will mount in your intended light though. Will it have a backing plate like the clips above? Will bolts be included?
Thank you.
You might want to change your picture to reflect what you are actually planning to build.
