I’m in for one
I’m in x 2
I’m in for one.
I’m in for one.
In for probably 2.
Incidentally Rey, could you make sure that the clip is a heavy enough gauge that it will not bend?
Yes, can you make it as stiff and strong as the first pictured clip. MAYBE a touch shorter or the same length.
2mm thickness should be ok?
I’m in.
I’m in for one.
Seems good. I’ll try to measure my clip soon.
I'm in for 5
I don't know about titanium but the stainless ones are around half a mm.
Im in with clip please…thx
Does anyone own the clip in 1st pic?
I do. I’ll try and measure thickness for tomorrow. If you make it similar and it fits lots of lights, I’ll get 4-5. Not sure how it will mount in your intended light though. Will it have a backing plate like the clips above? Will bolts be included?
Thank you.
You might want to change your picture to reflect what you are actually planning to build.
I’m in for 3.
Thanks,
Mike
