Seems good. I’ll try to measure my clip soon.
I'm in for 5
I don't know about titanium but the stainless ones are around half a mm.
Im in with clip please…thx
Does anyone own the clip in 1st pic?
I do. I’ll try and measure thickness for tomorrow. If you make it similar and it fits lots of lights, I’ll get 4-5. Not sure how it will mount in your intended light though. Will it have a backing plate like the clips above? Will bolts be included?
Thank you.
You might want to change your picture to reflect what you are actually planning to build.
I’m in for 3.
Thanks,
Mike
Just a comment, this clip is going to be similar to a McGizmo/Jetbeam/Convoy clip, no backing plate. The first 2 pictures in this thread are inaccurate. I’m still in for 2-5 now, these will be useful, just not what are shown in the first two pictures.
interested, pending actual
Top one looks good.
I’m in for two
I’m in for 2.
I’m in x 2
Pictures updated.
I like the design of the clip on the left. The hole can be used to thread onto a 1/4”–20 threaded screw. Think it’s a great idea making the pocket clip threadable. Mount it on any tripod.
I also like it with the bends of a clip from a CRK Sebenza.
Doesn’t look like enough room for two holes at the top if bent in similar fashion of a Sebenza clip.
Hope the design will work with a Zebralight SC62W. I want a different clip on mine.
Dimensions of nitecore ti clip. Make sure you use 1.05mm thick, like a McGizmo. The nitecore clip is too thin and flimsy.
Clip sizes
60.35mm long
12.40mm wide (at back)
0.75mm thick (flimsy nitecore clip)
1.05mm thick (McGizmo, use this)
3.0mm holes
7.0mm holes Center to Center. (curved clip).
Back to first bend, around 18mm
Back to last bend, around 50mm
Remember, use 1.05mm thick. Holes are 3mm wide and are 7mm centre to Center
These are for smaller bolts (2.5mm?). If you want McGizmo size, he uses 4/40 size bolts and has wide oval holes (see picture above)
Also if it’s a thick nitecore style clip, I’ll take 5.
