If I understand this correct: All I need is one of the boards, the switch, a resistor and a LED - nothing special like a cable running from one end of the light to the other or a special driver or something like that?
You don’t need to run a cable or a special driver. You will need to add a resistor to whatever driver you are using though. I have it working with 3 different driver designs, but I suppose there is still the potential that a driver may not function with this mod installed.
Can you link where this action is described for dummies?
Edit:
So, just adding a resistor between plus and minus of the driver/battery - correct?
So minus becomes plus for the LED through the resistor and the electrons can float…
Just ordered a few of the 17 and 20mm ones… can’t believe how cheap OSHpark is…
My first order from them btw
I have finally seen the light this is a really great idea.
I don’t know why it didn’t interested me before, but then i thought about that a low moon mode with a white lead still has lots of blue & green that can effect melatonin production & make the eyes lose its dark adaption & that we can buy cheap ebay red & amber ledstrips to harvest leds from to build red & amber glowing tailcaps instead.
Proper moon mode really should have red or amber, and without a moon mode in the firmware we can always start in a usable for daylight mode & simplify the UI
Do you think it is possible to connect it to the switch? so that when the switch is off the tailcap light is on but off when the switch is on.
But maybe only complicates things more than necessary for something that pulls so little current.
But then when the switch is ‘on’ so is your main light. I’m sure something could be done though.
Currently I use it on lights that have tail-cap lockout, which shuts off the tail LED’s when I don’t need them.
I also ordered some tiny switches to see if I could fit in a way to disable the tail light for storage, but it would be mounted on the inside next to the battery spring. I’m still working on that.
It would be something to disable the tail when the light isn’t in use. If I can get it to fit, it would be on the inside of the light, next to (or even inside) the batt- spring. You would have to take off the tailcap and use your finger or pencil or something to flip the switch. It would only affect the tail led’s, the regular light would function normally.
I’m not completely sure it will work at all, and wouldn’t really serve any purpose if the flashlight has tailcap lockout anyways.
Thanks for putting together a great idea. I just ordered some boards and components, enough make a couple dozen. Now for the long wait for everything to show up.
