probably different driver?
It’s really a lottery!!!
I bought XP-1 and XP-2, and they worked only with AAA Nimh…
the XP1 is my fav budget AAA light (imo better than the SF348), they need to lower the price on their AA models
I find it very strange that I have not found a single seller that mentions the fact that these lights actually contain XP-E2 emitters. I should have thought that would have been a good selling point, yet nobody mentions it.
Very odd. :~
Try asking if they actually have the product in hand — if they have their own warehouse and shipping.
Most of the websites, I think, are just different faces on the same business, which advertises, collects money, and orders things from somewhere else.
They’re called “dropshippers” — the people at the “seller” site who take the order won’t know what they’re selling until you tell them what you received.
When I have a question about something offered for sale, I always include “do you actually have one you can open up and look at?” — mostly I get honest answers that they have to ask whoever it is “they get it from” and that’s because they never actually set hands on the thing.
I’m not cynical enough yet, but I’m working on it.
Update to by post
Like in my other post i said i had 2 different led versions. The whiter led lights worked fine with the 10440.
I just put 10440 in the other one i have with the, the warmer/ orange one and it BROKE it.
So it is a total crap shoot with these. I would not use 10440s with this one. i guess i just got lucky with the first ones i got
Thanks for the update, i am sorry it burnt out for you
Dx have a 12mm driver that works good in the xp-1, including with an 10440.
There are also two versions of the BLF tiny10 7135 and FET plus matching tiny 12 drivers in the Oshpark projects thread. Rich at RMM can supply a flashed driver and the kit needed to put one together. The only extra thing you need to do is extend the led+ wire through the pcb and bend it over th mcu as a B+ contact and you can use 10440’s. I kind of doubt that the switch can handle the current from a BLF Tiny10DD so I would stick to the 7135 version with 2 chips. It’s possible the switch can be opened up and modded to withstand more current but I’d be very careful since plastic switch parts ate delicate.
I have an XP-1 in front of me. Is it necessary to wick the solder from the ground ring to remove the driver? It seems to be soldered to a brass insert that may be press fit into the aluminum head.
I think so, i haven’t done it on mine yet. My Hugsby XP-1 mod with an XP-L was an failure the led burnt out.
I have bothered to try to fix it since then.
The only one i know who has upgraded the driver is ohoya
I think he said he said he was able to cut through the solder, i tried that but failed.
I tried to use the soldering iron to heat up the solder & get out the driver by using a solder sucker pump tool, but failed.
If i would try again i would probably try my heatgun & liquefy the solder & hopefully get the driver out.
Good luck
I can attest that the AK-007 driver from DX works pretty well with 10440 (and also with AAA). I’ve replaced the stock XP-1 driver with it in one light.
And yes, I was able to remove the stock driver by cutting (patiently) through the solder joint and shaving the solder off. Actually, for the AK-007 when I added it back in, I just soldered the original emitter/emitter leads to the AK-007 and the AK-007 is just kind of sitting there. I never bothered to solder the driver to the brass ring inside the head, and it seems to work ok like that.
As far as I know, there was an XP-1 (1 x AAA) and an XP-2 (2 x AAA) lights, and they had different drivers.
The driver from the XP-2 could actually take 1 x 10440 (you’d need to use it with a dummy AAA or use it in an XP-1 body with the XP-2 head).
The XP-1 head would burn out with a 10440… a couple of us tried, and found that out the hard way.
So, bottom line:
1) You can replace the original XP-1 or XP-2 driver with an AK-007 driver, but the AK-007 is a 1xAAA or 1x10440 driver only.
2) The XP-2 driver will work with 1x10440.
The XP-1 and XP-2 are still almost my favorite AAA/10440 lights, and as weird as it sounds, I like the 2xAAA form factor, so I run the XP-2 with 1 x 10440 and 1 dummy AAA.
Jim
There are two sections of the battery tube which are narrow enough for the clip so it can be reversed. However, swapping the head for the tail also works and the clip fits best on the narrower tube section (section without “Hugsby”). This one seems to be a neutral tint, somewhere between a cool white and a Nichia.
With regards to the head swapping of XP-1 and XP-2… I swapped the heads over but continued to use AAA rather than lithium batteries… Both lights still work. So now I have a really bright (sort of overdriven) XP-1 head with XP-2 body and a dimmer XP-2 head with XP-1 body.
I like this arrangement because the dimmer light can be used as a bedside light so you don’t blind yourself at night and the brighter light is more exciting :bigsmile: and a very useful AAA light.
Oh, I like that idea. Will definitely give that a shot. Thanks for sharing logesearle. :)
No problem!! And just to add to the above… I have only used cheap alkaline AAA’s with the XP-1 head and XP-2 body… I’m not sure the XP-1 head would appreciate some really good AAA cells in series :Sp
These XP-1’s have replaced my Microstream. I thought about running a XP-1 with the 10440, but see here and other places that it is a gamble. Now that I have hands on these fine little lights, I find that on an alkaline AAA they are between the Streamlight Microstream with either an alkaline or a 10440 in terms of brightness. So, happy with their output, I ordered several more for backups and will run them with AAA alkaline batteries and be very satisfied with them. I do love the AAA format for general carry and useability, so the Microstream was my EDC for quite a while, but losing a ~$17 light can put a damper on a day for me, these will spread that pain out as I can get four for the price of one Microstream, and the Hugsby XP-1s are brighter on alkaline AAA batteries!
Beware of the alkaleak boojum! In high drain(read boost applications) this is more likely. I’m making a pair of brass split bushings to separate the head parts. When it’s done I’ll mail them to anyone interested. I just ask that you pass them on to someone else when you’re done.
Well let me know when you are done with the split bushings, I will use them and mail them on to the next person who needs them.
Haven’t even been home to turn over the laundry pile. Thanks for the reminder.
I attempted my second dedome. The first was successful on my Thorfire TG06, the second on my Hugsby XP-1, not… I had such good response from the first dedome on the Thorfire to a nice NW from the original bluish tint that I pressed on to the XP-1. I believe I rushed the solvent method and when I tried to get the residue off of the LED, I may have damaged the wires…. I have a couple of more on the way, and I ordered some emitters on an 8mm board to try a direct swap on the XP-1… Worst case, I am out a couple of bucks for the new emitter… Still like this light, back to the microstream for now…
