Test/Review of LG 18650 MH1 3200mAh (Cyan)
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 4 hours ago
DSC_8197
Official specifications:
  • Nominal capacity: 3200 mAh
  • Minimum capacity: 3100 mAh
  • Nominal Voltage: 3.63V
  • Standard Charge: Constant current 0.5C (1550mA), Constant voltage 4.2V, End current(Cut off) 50mA
  • Max. Charge Voltage: 4.2 ± 0.05V
  • Max. Charge Current: 1.0 C (3100mA)
  • Standard Discharge: Constant current 0.2C (620mA), End voltage(Cut off) 2.5V
  • Max. Discharge Current: 10A
  • Weight Approx.: 49.0 g
  • Cycle life: 500 (0.5C charge and discharge)
  • Operating Temperature: Charge 0 ~ 45°C, Discharge -20 ~ 60°C
  • Storage Temperature: 1 month -20 ~ 60°C, 3 month -20 ~ 45°C, 1 year -20 ~ 20°C
LG%2018650%20MH1%203200mAh%20(Cyan)-info
This is a cell with high capacity for fairly high loads and with good cycle life.
DSC_8196
DSC_8198 DSC_8199
DSC_8200
DSC_8201
LG%2018650%20MH1%203200mAh%20(Cyan)-Capacity
The matching between the two cell is very impressive and capacity do not drop much with load. I looks like the rated current of 10A is very resonable.
LG%2018650%20MH1%203200mAh%20(Cyan)-CapacityTimeHours
LG%2018650%20MH1%203200mAh%20(Cyan)-Energy
LG%2018650%20MH1%203200mAh%20(Cyan)-PowerLoadTime
LG%2018650%20MH1%203200mAh%20(Cyan)-TripCurrent
LG%2018650%20MH1%203200mAh%20(Cyan)-Charge
Conclusion
There is not much to say about this cell, it looks like a very good cell and is designed for use with standard 4.2 volt chargers.
Notes and links
Compare to 18650 and other batteries
Major
Major's picture
Last seen: 6 years 6 months ago
Thank you for the test very informative. Seems like the MH1 holds a higher voltage and has virtually the same capacity and is cheaper than the panasonic 3400mah!
shrike3612
Thank you for nice review.
DB Custom
DB Custom's picture
Last seen: 2 weeks 6 days ago
Good to see top quality options available, thank you for checking it out for us. Smile
