Thats a cool afordable flashlight i found on aliexpress, very powerful, waterproof and with a cool magnetic switch. What do you think of it ? It’s the Skyray SY-068 and it seems to be around 3000l umens. Thank you !
If this torch is going to be needed on a regular basis, then I would recommend you invest in a set of more reliable batteries, likewise with the charger. As for the torch that is up to you, choose the design that you like best, you’ll have a better experience with a light with good track record
You need this light to illuminate the woods at night, a multi led reflector setup may not be the best choice because of the floody beam and cool white tint, it won’t reach very far and have poor color reproduction. For me 2,000 lumens is more than enough for outdoors, anything beyond that is a waste of battery life and unnecessary heat.
If you’re willing to mod, which is just a very easy emitter swap, I recommend the Yezl Y3 + extension tube modded with an MT-G2. It will give you about 2,000lm but in outdoors throw is more important than just high output. This will go for about $45. http://www.gearbest.com/led-flashlights/pp_68858.html
If you’re willing to spend a little bit more, have a look at the shadow JM30 with MT-G2. For $65 you can get excellent build quality and tons of light. http://www.cnqualitygoods.com/goods.php?id=2216
